HPC/Network Access
< HPC
Jump to navigation
Jump to search
Accessing Carbon
To use Carbon you need an active user proposal and your Argonne domain username and password. You must renew your password about every 6 months.
From an onsite and Argonne-owned computer
Connect with a Secure Shell client program directly to carbon.cnm.anl.gov
From any other computer
Employ one of the following mechanisms:
- Argonne employees may wish to log into the Argonne VPN first, then access the Carbon login nodes.
- Otherwise, use CNM's SSH gateway, see next section.
Requirements for using the SSH gateway
To access the gateway:
- You must be a user on a CNM proposal that is active or has recently expired (within the last 6 weeks).
- Use your Argonne password to log in.
- The gateway is needed for port forwarding only. Do not run any commands or store any files on this machine.
Using the SSH gateway
Setup for interactive use and file transfers
SSH GUI Applications
- Mac OS X
- Windows
- Virtual Desktop (VNC)
Additional information:
Password Policies
The methods described above will grant you, the holder of your Argonne domain password and private ssh key, access to your account on Carbon. As with any Argonne computer system, the following rules apply:
- Keep passphrases and passwords private – do not share them with anyone, including administrators that you know or don't know.
- Keep your private key file private - do not share it with anyone.
- Use a strong passphrase following DOE password regulations.
