Nanofabrication/Equipment/Critical Point Dryer
From CNM Wiki
Revision as of 19:51, November 24, 2020 by Csmiller (talk | contribs)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
The CPD 030 Critical Point Dryer is an efficient method of drying delicate samples without damaging its structure through surface tension that occurs when changing from the liquid to the gaseous phase.
Features
  • Integrated heating and refrigeration
  • Easy to use interface
  • Low CO2 consumption
Applications
  • Critical point CO2 drying of delicate samples
Specifications
  • 40mm x 36mm chamber size
  • 70ml CO2 capacity
  • Up to 150 bar chamber pressure
  • Cooling: 2-12C
  • Heating: 30-45C
User Proposal Feasibility
When requesting the use of this instrument, please provide the following information in your user proposal:
  • Sample materials, shapes, and sizes
  • Number of samples to process or number of times of instrument usage
Questions? Please contact the instrument custodian before submitting your proposal.
