HPC/Applications/matlab
From CNM Wiki
Introduction
MATLAB on Carbon is currently licensed to run on clogin5 only, access is restricted to Argonne employees, and only one user at a time can run MATLAB.
To get started, load the "matlab" module as described at HPC/Module Setup.
Running MATLAB
Choose how to run the application:
GUI, over X11
matlab
Depending on your network connection this might be rather slow.
GUI, under VNC
Follow the general VNC instructions, then start matlab in the terminal within the virtual desktop.
Command line
For very slow connections or just basic calculations, you could save some startup time by simply using the text interface. Unset the DISPLAY variable before starting matlab.
DISPLAY="" matlab
Troubleshooting
Access
You must be a member of the "employees" group on Carbon to run MATLAB. If you are not, you could load the "matlab" module but it will not enable anything.
  • To inspect your current group membership, run:
groups
The word "employees" must show. Since the group has been added only this week (Feb. 5, 2013), you may need to log out and back in to pick up the group membership.
Running on a host that is not licensed
License checkout failed.
License Manager Error -9
The hostid of your computer ("001122334455 001122334466") does not match the hostid of the license file (001122334400).
Solution: log in to clogin5 and retry. If you use the Mega SSH gateway, review the updated instructions for Linux/Mac/Cygwin or PuTTY on Windows on how to configure and use port forwarding to reach a specific login node.
License in use
This error may occur when:
-The hostid of this computer does not match the hostid in the license file.
-A Designated Computer installation is in use by another user.
If no other user is currently running MATLAB, you may need to activate.
Solution: Wait a half hour or so and retry. You can identify the user currently running matlab using the "ps aux | grep matlab" command. Be considerate in negotiating access with that user.
