Email Services/Zimbra User Documentation
Zimbra mail and calendaring functions are accessible using a number of existing protocols and client programs on various desktop computing platforms. Notably, the following clients are supported:
- MS Outlook (Online, Offline, Cached Mode)
- Eudora
- Apple Mail and iCal
- Thunderbird/Sunbird, Evolution
- RSS readers
For more details, see What is Different About Zimbra?.
FAQ
Mail Client Configuration
Desktop Client HOWTOs
Mobile Device Client HOWTOs
- Android (T-Mobile G1)
- BlackBerry
- iPhone
- Treo with VersaMail 3
- Treo with VersaMail 2
- Windows Mobile 5
- References
Generic IMAP Config
- Username: [email protected]
- SSL: Yes (port 993 if asked)
- IMAP Server: zimbra.anl.gov
- Example URI (used by some IMAP clients): imaps://zimbra.anl.gov/INBOX/
Generic POP Config
- SSL: Yes (port 995 if asked)
- Pop Server: zimbra.anl.gov
Generic SMTP Config
- SMTP Server: zimbra.anl.gov
- SSL: Yes
- Port: 465
- Authentication: Yes (Choose either "PLAIN" or "LOGIN")
Calender Client Configuration
CalDAV
Q) Can I use CalDAV to sync my calendar?
A) Yes. Point your CalDAV client at your calendar with the URI below. Replace "my_username@my_domain_name.anl.gov" with your fully qualified Zimbra username (Ie: [email protected]):
Thunderbird w/ Lightning
Use: https://zimbra.anl.gov/principals/users/my_username@my_domain_name.anl.gov/calendar_name Authentication: my_username@my_domain_name.anl.gov Must map each calendar separately
Mac OS X Leopard (10.5) or later
iPhone users note:
- If you wish to sync any of your calendars with an iPhone, you'll need to ensure that none of the Calendars have a space in their name. Log into Zimbra and rename any calendars (even ones you have that are shared from someone else) such that there are no spaces in the names. Use CamelCase, hyphens or underscores.
- Any events you add on your iPhone cannot go directly onto one of these calendars, as iTunes will only let you add to a "local" calendar. If you typically don't add appointments on your iPhone, this is probably not a big deal. If you do, it would be a good idea to designate a local calendar to be for the iPhone, then when you sync you can drag appointments to the right calendar.
We expect these issues to go away once iPhone 2.0 is released with ActiveSync support, in which case your phone can sync directly with the server without using the cradle.
Setting up iCal for CalDAV
- If you have previously installed the Zimbra Sync Preference Pane, go into that and uncheck Calendar syncing. If you need Contacts syncing, you'll still need this connector, otherwise you can remove it.
- Open iCal, and then open its Preferences (Command-,).
- Go into the accounts tab.
- Add a new account by clicking the plus sign (+) at the bottom of the left hand window.
- Description is whatever you like (eg, "Zimbra")
- Username is your zimbra login name
- Password is your Argonne Domain Password.
- Click the Server Options triangle, and in the URL enter:
https://zimbra.anl.gov/principals/users/<username>@zimbra-domain/
- If you're at all unsure what your full <username>@zimbra-domain is, simply login to Zimbra, click Preferences, then look at the Accounts tab. At present, almost all users in MCS, ALCF, and the CELS office are in zimbra.mcs.anl.gov, for example.
After this is done, all your calendars will show up in iCal. You can drag them into the order you like, uncheck the ones you don't want to see, change their colors, etc. Note: You'll get the alarms for all Calendars by default. You can either turn off all alarms in iCal (in Preferences, Advanced), or on each Calendar you don't want alarms for, right-click and choose "Get Info", then check "Ignore alarms".
Changes in iCal are uploaded to the server immediately. Changes on the server are refreshed in iCal on the schedule chose in the Accounts tab, or on-demand by right-clicking the calendar and selecting "Refresh".
In order to add an appointment to a CalDAV Calendar, be sure it's the one highlighted in the calendar list on the left. If you try to add to a calendar to which you do not have write access, you will get an error. Deleting the appointment will fix that.
iCal integration
Q) The Zimbra site mentions iCal (Mac OS) integration. How can I take advantage of this?
A) If you only wish to sync Calendars and not Contacts, and are running Leopard, then see CalDAV for a more reliable sync method. Otherwise, there is a "Connector" that you will need to install. More information about the connector, including links to an installation and usage document can be found below.
- When the Zimbra Collaboration Suite Connector for Apple iSync is installed, users can synchronize their Zimbra contacts and calendars with Apple Address Book, iCal, and Microsoft® Entourage®.
Download the Zimbra iSync Connector
- Zimbra iSync Connector Document (Read this first!)
- Download the latest version of the Zimbra iSync Connector
Mozilla Lightning/Sunbird
Please note that Mozilla Lightning/Sunbird software and still very much under development.
- As of Sunbird 0.8 with ZCS 5.06, one can subscribe to a Zimbra calendar in order to view and modify items. However, things are still quirky.
- As of 5.0RC1 and earlier, Calendar events cannot be 'deleted' from Sunbird. They must be marked as 'Status: Canceled' through the menu Options -> Status -> Canceled .
Follow these steps to get your calendar to display in Sunbird:
- File > Subscribe to Remote Calendar > Create a new calendar "on the network" >
- Format: iCalendar (ICS)
- Location: https://zimbra.anl.gov/zimbra/home/username/calendar?fmt=ics (replace "username" with your Zimbra account username.)
Links
- http://wiki.zimbra.com/index.php?title=Accessing_Zimbra_Collaboration_Suite_with_Thunderbird
- http://wiki.zimbra.com/index.php?title=Connectors_for_Lightning/Sunbird
- http://www.zimbra.com/forums/showthread.php?t=2454
- http://wiki.zimbra.com/index.php?title=Thunderbird_%26_Lightning
Lightning/Sunbird Feedback
- If I set a reminder on an appointment in ZCS 5.06, then disable the reminder in Sunbird 0.8, the reminder doesn't get removed from Zimbra. Instead Sunbird adds it again from Zimbra during its next update.) --Lehman 22:00, June 15, 2008 (CDT)
Is there a message size limit?
Yes. The maximum message size is currently set to 100MB.
Is there a limit to the number of attachments I can add to a message via the web client?
Not that we have found. We have tested it with as many as 16 attachments thus far.
Can I have the Web interface startup with the calendar instead of mail?
You can do this from the URL with the "app" option:
