Locations
From HELIOS Digital DAQ
Revision as of 23:38, February 6, 2026 by Ttang (talk | contribs) (→Nat Box / Rounter)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
Physical Location
Network Location Information
A drawing of the network is like this (2021-01-21).
The CISCO router is the only way to the onenet and internet.
The HP Switch is a main switch for all devices, like the DAQ PC and the MAC.
The HELIOS-DB and the windowsXP connects to the onenet directly.
We added 2 Network Power switch
IP: 192.168.1.106 for Target fan
IP: 192.168.1.115 for DAQ
DAQ Computer
The data acquisition computer for digital HELIOS sits behind a NAT box. The NAT box is located at
digios1.onenet (192.168.203.52)
or from the Mac
192.168.1.2
The HELIOS-DB, Mac2017 and the windowsXP connect to the onenet, the IPs are
HELIOS-DB : 192.168.203.23 (nickname: heliosdb)
windowsXP : 192.168.203.37
mac2017 : 192.168.203.34 (nickname: mac2017)
Login outside ANL
only for PC at onenet.
ssh -J <username>@login.phy.anl.gov <accountName>@<onenet_IP>
PC accountName onenetIP
DAQ helios digios1
Nat Box / Rounter
The login for the cisco (cisco data page) is uname cisco and the gammasphere password
192.168.1.1
Notes on cisco setup: network -> wan -> iPv4 -> static -> 192.168.203.52 -> default .1 -> DNS .1
Computer IP
IOCs 192.168.1.2X
DAQ 192.168.1.2
MAC2020 192.168.1.164
MAC2017 192.168.1.193
Windows XP 192.168.1.191
DAQ power switch 192.168.1.115
Terminal server 192.168.1.3
HELIOS Mag Ctrl Pi 192.168.1.208
To scan all "active" devices in the CISCO network:
$nmap -F 192.168.1.*
Terminal Server
Portserver TS16 MEI
Info? (2.6.23-431.5.1.el6.i686 (RH 4.4.7-3) Login with root and gammasphere pswrd
telnet 192.168.1.3 200[1-X]
In the DAQ-PC, the IP and the corresponding "nickname" are saved in
/etc/hosts
$cat /etc/hosts
127.0.0.1		localhost.localdomain localhost
::1		localhost6.localdomain6 localhost6
192.168.1.1	digios1
192.168.1.3	ts
192.168.1.20	ioc0
192.168.1.21	ioc1
192.168.1.22	ioc2
192.168.1.23	ioc3
192.168.1.24	ioc4
192.168.1.234	tllptgs
Physical Locations and ID's of Digitizers / Routers / Triggers
Really need a few figures with labels / diagrams.
  • Serial numbers of system hardware
  • Board ID numbers for data processing
  • IP address and names of modules
