Locations
From HELIOS Digital DAQ
Physical Location
Network Location Information
A drawing of the network is like this (2021-01-21).
The CISCO router is the only way to the onenet and internet.
The HP Switch is a main switch for all devices, like the DAQ PC and the MAC.
The HELIOS-DB and the windowsXP connects to the onenet directly.
We added 2 Network Power switch
IP: 192.168.1.106 for Target fan
IP: 192.168.1.115 for DAQ
DAQ Computer
The data acquisition computer for digital HELIOS sits behind a NAT box. The NAT box is located at
digios1.onenet (192.168.203.52)
or from the Mac
192.168.1.2
The HELIOS-DB, Mac2017 and the windowsXP connect to the onenet, the IPs are
HELIOS-DB : 192.168.203.23 (nickname: heliosdb)
windowsXP : 192.168.203.37
mac2017 : 192.168.203.34 (nickname: mac2017)
Login outside ANL
only for PC at onenet.
ssh -J <username>@login.phy.anl.gov <accountName>@<onenet_IP>
PC accountName onenetIP
DAQ helios digios1
Mac2017 heliosdigios mac2017
Nat Box / Rounter
The login for the cisco (cisco data page) is uname cisco and the gammasphere password
192.168.1.1
Notes on cisco setup: network -> wan -> iPv4 -> static -> 192.168.203.52 -> default .1 -> DNS .1
IOC's are
192.168.1.2X
DAQ computer (digios1) is
192.168.1.2
MAC2020 computer (helios-iMac) is
192.168.1.164
Target Fan power switch (target-pwrswitch) is
192.168.1.106
DAQ power switch is
192.168.1.115
There are some unknown IP
192.168.1.3
192.168.1.81
To scan all "active" devices in the CISCO network:
$nmap -F 192.168.1.*
Terminal Server
Portserver TS16 MEI
Info? (2.6.23-431.5.1.el6.i686 (RH 4.4.7-3) Login with root and gammasphere pswrd
telnet 192.168.1.3 200[1-X]
In the DAQ-PC, the IP and the corresponding "nickname" are saved in
/etc/hosts
$cat /etc/hosts
127.0.0.1		localhost.localdomain localhost
::1		localhost6.localdomain6 localhost6
192.168.1.1	digios1
192.168.1.3	ts
192.168.1.20	ioc0
192.168.1.21	ioc1
192.168.1.22	ioc2
192.168.1.23	ioc3
192.168.1.24	ioc4
192.168.1.234	tllptgs
Physical Locations and ID's of Digitizers / Routers / Triggers
Really need a few figures with labels / diagrams.
  • Serial numbers of system hardware
  • Board ID numbers for data processing
  • IP address and names of modules
