PV List
in terminal:
caget = read PV value caput = set PV or command
known PV list
=========================== GOLBAL PV GLBL:DIG:<PV> -- for whole system VME$$:MDIG$$:<PV> -- for whole digitizer VME$$:MDIG$$:<PV>$$ -- for write indivual channel VME$$:MDIG$$:<PV>$$_RBV -- for read onlu
Items | PV | R/W | Global | DIG | CH |
Disc. Hits | disc_count | R | X | X | O |
Acc. Hits | ahit_count | R | X | X | O |
Acc. Evts | accepted_event_count | R | | | |
Drop. Evts | dropped_event_count | R | | | |
Live TS | CV_LiveTS | R | | | |
trigger mode | trigger_mux_select | R/W | | | |
trig. pol. | trigger_polarity | R/W | O | O | O |
channel enable | channel_enable | R/W | O | O | O |
threshold | led_threshold | R/W | O | O | O |
| p1_window | R/W | O | O | O |
| p2_window | R/W | O | O | X |
| k_window | R/W | O | O | O |
| k0_window | R/W | O | O | O |
| d_window | R/W | O | O | O |
| d2_window | R/W | O | O | O |
| d3_window | R/W | O | O | O |
| m_window | R/W | O | O | O |
| pileup_mode | R/W | O | O | O |
Trace lenght delay | raw_data_length | R/W | O | O | O |
Trace lenght | raw_data_window | R/W | O | O | O |
| CFD_fraction | R/W | O | O | O |
Baseline Delay | delay | R/W | O | O | X |
Baseline channel | baseline_start | R/W | O | O | O |
Min overlap window | win_comp_min | R/W | O | O | X |
Max overlap window | win_comp_max | R/W | O | O | X |
Discr. Width | disc_width | R/W | O | O | O |
| peak_sensitivity | R/W | O | O | X |
| tracking_speed | R/W | O | O | X |
| preamp_reset_delay | R/W | O | O | O |
| holdoff_time | R/W | O | O | X |
| cfd_mode | R/W | O | O | X |
| veto_gate_width | R/W | O | X | X |
enable preamp reset | preamp_reset_delay_en | R/W | O | O | O |
=========================== Other PV: Online_CS_SaveData | set Save Data register Online_CS_StartStop | set DAQ start stop DAQC$_CV_SendRate DAQC$_CV_NumSendBuffers DAQC$_CV_BufferAvail VME32:RTR$:TimestampB VME32:MTRG:TIMESTAMP_B VME32:RTR$:reg_MISC_STAT_RBV VME32:MTRG:MAN/AUX.DESC VME32:MTRG:SUM_X.DESC VME32:MTRG:SUM_Y.DESC VME32:MTRG:SUM_XY.DESC VME32:MTRG:RAW_TRIG_RATE_COUNTER_$_RBV VME32:MTRG:XTHRESH VME32:MTRG:YTHRESH VME32:RTR1:reg_MISC_STAT_RBV | router lock state VME32:RTR2:reg_MISC_STAT_RBV VME32:RTR1:LOCK_COUNT_A_RBV | lock counter VME32:RTR1:LOCK_COUNT_B_RBV | lock counter VME32:RTR1:LOCK_COUNT_C_RBV | lock counter VME32:RTR1:CLEAR_DIAG_COUNTERS 1 | reset counter
router lock state
it is a 16bit hex number. for example, a good lock state is 17668 = 0x4504 = bx0100 0101 0000 0100
The bit is read like this: ( first bit is the most left bit )
bit-01 | Lock Error | 0 bit-02 | All Lock | 1 bit-03 | not use | 0 bit-04 | not use | 0 bit-05 | L init state 8 | 0 bit-06 | L init state 4 | 1 bit-07 | L init state 2 | 0 bit-08 | L init state 1 | 1 bit-09 | CPLD 8 | 0 bit-10 | CPLD 4 | 0 bit-11 | CPLD 2 | 0 bit-12 | CPLD 1 | 0 bit-13 | Fast str | 0 bit-14 | R Lock | 1 bit-15 | NIM in A | 0 bit-16 | NIM in B | 0
