Data Storage
Jump to navigation
Jump to search
in DAQ
The raw data is stored in
/media/
at Nov-11-2019, there are 3 Hard disks
/media/DIGIOSDATA4 -- 3TB, used /media/DIGIOSDATA5 -- 6TB, used (from H077_29Al, 2020-11) /media/DIGIOSDATA6 -- 6TB, empty (borrow to MUSIC, 2020-11-21)
After each run, the previous run will be push to LCRC. see Globus
mount disk at startup
1) Get name, UUID, file system Type of detected disks
[root@digios1 helios]# blkid /dev/sda1: UUID="6afd3d3e-d944-44d8-95cf-64d76118763a" TYPE="ext4" /dev/sda2: UUID="99b398a6-20c6-4f2b-b680-a4bc8afce1c4" TYPE="ext4" /dev/sda3: LABEL="_SL-62-i386-Live" UUID="dbccbb90-6026-4913-931a-b71e169d17ed" TYPE="ext4" /dev/sda5: UUID="de9962db-d5ec-4f07-8da7-3ef50c257135" TYPE="swap" /dev/sda6: UUID="958f0586-b338-4255-ab62-a86447e549e4" TYPE="ext4" /dev/sdc: LABEL="DIGIOSDATA5" UUID="48e123eb-7613-4ef4-b9e4-eb53283ddcdf" TYPE="ext4" /dev/sdb: UUID="575cde2b-1adf-4bf0-af91-74601ef294c1" TYPE="ext4"
2) make mount point
/media/DIGIOSDATA<X>
make sure chmod, such as
drwxrwxrwx. 14 root root 4.0K Aug 25 12:06 DIGIOSDATA4 drwxrwxrwx. 5 helios helios 4.0K Nov 11 21:07 DIGIOSDATA5
3) edit /etc/fstab, here is the content of the file
# # /etc/fstab # Created by anaconda on Wed Jan 30 13:24:43 2013 # Last edit by Ryan on Sat Nov 21 16:42 2020 # # Accessible filesystems, by reference, are maintained under '/dev/disk' # See man pages fstab(5), findfs(8), mount(8) and/or blkid(8) for more info # UUID=dbccbb90-6026-4913-931a-b71e169d17ed / ext4 defaults 1 1 UUID=6afd3d3e-d944-44d8-95cf-64d76118763a /boot ext4 defaults 1 2 UUID=958f0586-b338-4255-ab62-a86447e549e4 /global ext4 defaults 1 2 UUID=99b398a6-20c6-4f2b-b680-a4bc8afce1c4 /home ext4 defaults 1 2 UUID=de9962db-d5ec-4f07-8da7-3ef50c257135 swap swap defaults 0 0 UUID=575cde2b-1adf-4bf0-af91-74601ef294c1 /media/DIGIOSDATA4 ext4 defaults 0 0 UUID=48e123eb-7613-4ef4-b9e4-eb53283ddcdf /media/DIGIOSDATA5 ext4 defaults 0 0 #UUID=43f42e85-fd83-42d7-8e4b-46323a858cc3 /media/DIGIOSDATA6 ext4 defaults 0 0 tmpfs /dev/shm tmpfs defaults 0 0 devpts /dev/pts devpts gid=5,mode=620 0 0 sysfs /sys sysfs defaults 0 0 proc /proc proc defaults 0 0 /dev/sdb /media/DIGIOSDATA4 ext4 users,rw,owner,umask=000 0 0 /dev/sdc /media/DIGIOSDATA5 ext4 users,rw,owner,umask=000 0 0 #/dev/sdd /media/DIGIOSDATA6 ext4 users,rw,owner,umask=000 0 0 #/dev/sdd /media/DIGIOSDATA3 vfat users,rw,owner,umask=000 0 0
in MAC
The data will be donwloaded at
~/digios/analysis/data
in LCRC
The experimental data is stored at
/lcrc/project/HELIOS/experimentsData/
= Current folder structure
Each experiment data will be stored inside the folder with the experiment ID.
For example, h070_146Nd, in DAQ will be stored in
/media/DIGIOSDATA4/h070_146Nd/
Under this folder, there are 3 sub-folders
/media/DIGIOSDATA4/h070_146Nd/data /media/DIGIOSDATA4/h070_146Nd/merged_data /media/DIGIOSDATA4/h070_146Nd/root_data
