Globus
Globus is a "thing" that bridge two data locations. For example, we use it to transfer file from the DAQ and LCRC.
First, login https://www.globus.org/ with your ANL account
Once you are in globus, go to File manager, find "LCRC DTN", you will need LCRC account for it. The password of LCRC is NOT the SSH one. Once you done, you can navigate to /lcrc/project/HELIOS (assume you also have the right for the HELIOS project).
Then, create an endpoint on the DAQ. https://docs.globus.org/how-to/globus-connect-personal-linux/
Remark. using helios@digios1 cannot access /media/ You need to login as dgs@digios1
