Locations
Network Location Information
Need a nice drawing of the network
DAQ Computer
The data acquisition computer for digital HELIOS sits behind a NAT box. The NAT box is located at
digios1.onenet
or
192.168.203.52
The actual digios computer sits at
192.168.1.2
on the LAN setup by the NAT box
Nat Box
The login for the cisco (cisco data page) is uname cisco and the gammasphere password
192.168.1.1
Notes on cisco setup: net -> wan -> iPv4 -> static -> 192.168.203.52 -> default .1 -> DNS .1
IOC's are
192.168.1.2X
DAQ computer is
192.168.1.2
Terminal Server
Info? (2.6.23-431.5.1.el6.i686 (RH 4.4.7-3) Login with root and gammasphere pswrd
telnet 192.168.1.3 200[1-X]
Physical Locations and ID's of Digitizers / Routers / Triggers
Really need a few figures with labels / diagrams.
- Serial numbers of system hardware
- Board ID numbers for data processing
- IP address and names of modules
EPICS DATA BASE
IOC boot command file
/global/devel/gretTop/9-22/dgsIoc/iocBoot/iocArray/vme0X.HELIOS.cmd
Databases that are loaded
/global/devel/gretTop/9-22/dgsIoc/dbd/gretDet.dbd /global/devel/gretTop/9-22/dgsIoc/db/dgsDigRegisters.template /global/devel/gretTop/9-22/dgsIoc/db/asynDebug.template /global/devel/gretTop/9-22/dgsIoc/db/dgsDigUser.template /global/devel/gretTop/9-22/dgsIoc/db/daqCrate.template /global/devel/gretTop/9-22/dgsIoc/db/onMon.template /global/devel/gretTop/9-22/dgsIoc/db/gretVME.template /global/devel/gretTop/9-22/dgsIoc/db/daqBoard.template /global/devel/gretTop/9-22/dgsIoc/db/daqSegment.template /global/devel/gretTop/9-22/dgsIoc/db/dgsGlobals_HELIOS_VME01.db
Some other locations:
startup = "/global/devel/gretTop/9-22/dgsIoc/iocBoot/iocArray"
putenv("ARCH=vxWorks-ppc604_long")
putenv("IOC=iocArray")
top = "/global/devel/gretTop/9-22/dgsIoc"
putenv("TOP=/global/devel/gretTop/9-22/dgsIoc")
topbin = "/global/devel/gretTop/9-22/dgsIoc/bin/vxWorks-ppc604_long"
sncseq = "/global/devel/supTop/31410/sncseq-2.0.12"
putenv("SNCSEQ=/global/devel/supTop/31410/sncseq-2.0.12")
sncseqbin = "/global/devel/supTop/31410/sncseq-2.0.12/bin/vxWorks-ppc604_long"
asyn = "/global/devel/synApps/asyn/asyn4-17"
putenv("ASYN=/global/devel/synApps/asyn/asyn4-17")
asynbin = "/global/devel/synApps/asyn/asyn4-17/bin/vxWorks-ppc604_long"
epics_base = "/global/devel/base/base-3.14.12.1"
putenv("EPICS_BASE=/global/devel/base/base-3.14.12.1")
epics_basebin = "/global/devel/base/base-3.14.12.1/bin/vxWorks-ppc604_long"
vxstats = "/global/devel/supTop/31410/vxStats"
putenv("VXSTATS=/global/devel/supTop/31410/vxStats")
vxstatsbin = "/global/devel/supTop/31410/vxStats/bin/vxWorks-ppc604_long"
gretvme = "/global/devel/gretTop/9-22/dgsIoc/../gretVME"
putenv("GRETVME=/global/devel/gretTop/9-22/dgsIoc/../gretVME")
gretvmebin = "/global/devel/gretTop/9-22/dgsIoc/../gretVME/bin/vxWorks-ppc604_long"
gretdig = "/global/devel/gretTop/9-22/dgsIoc/../dgsDrivers"
putenv("GRETDIG=/global/devel/gretTop/9-22/dgsIoc/../dgsDrivers")
gretdigbin = "/global/devel/gretTop/9-22/dgsIoc/../dgsDrivers/bin/vxWorks-ppc604_long"
trigger = "/global/devel/gretTop/9-22/dgsIoc/../dgsDrivers"
putenv("TRIGGER=/global/devel/gretTop/9-22/dgsIoc/../dgsDrivers")
triggerbin = "/global/devel/gretTop/9-22/dgsIoc/../dgsDrivers/bin/vxWorks-ppc604_long"
gretdata = "/global/devel/gretTop/9-22/dgsIoc/../dgsData"
putenv("GRETDATA=/global/devel/gretTop/9-22/dgsIoc/../dgsData")
gretdatabin = "/global/devel/gretTop/9-22/dgsIoc/../dgsData/bin/vxWorks-ppc604_long"
autosaverestore = "/global/devel/supTop/31410/asr4"
putenv("AUTOSAVERESTORE=/global/devel/supTop/31410/asr4")
autosaverestorebin = "/global/devel/supTop/31410/asr4/bin/vxWorks-ppc604_long"
