Ideas
From HELIOS Digital DAQ
List of things following DigiOS beam time
Email for JTA - 10/2017
Performance
-- Understanding the triggering better
-- Adding in the RF Timing
-- How to force data to file if rates are low
Increase system stability
-- How to govern and automatically monitor the buffers -> looking into the THROTTLE variables and setup start with finding all THROTTLE variables
/global/devel/gretTop/9-22/dgsIoc/iocBoot/iocArray/vme0X.HELIOS.cmd
load the databases, which db's hold the THROTTLE?
-- How to query the network / system to wake it up on startup -> tried to touch files but then IOC closes because files exist, also tried to ping iocX but get no response. Need to look into receiver code?
-- How to reboot things remotely
-- Triggers / TS stop updating on the GUI (but data seems to be coming in)
-- Triggers / TS stop updating from one of the VMEs?
Items for experimental setup/startup
-- How to better use the pulser
-- How to get a signal out of the digitizer for use as a scope
Data storage and processing
-- Stability and automation for disk mounting
-- understand the file writing with the gtReciever (max file size etc.)
-- How to transfer only data that is not on the mac already
-- Improved way to sum up the data runs
