Ideas
From HELIOS Digital DAQ
Revision as of 20:25, September 26, 2017 by Crhoffman (talk | contribs)
List of things following DigiOS beam time
Performance
-- Understanding the triggering better
-- Adding in the RF Timing
-- How to force data to file if rates are low
Increase system stability
-- How to govern and automatically monitor the buffers
-- How to query the network / system to wake it up on startup -> 'tried to touch files but then IOC closes because files exist, also tried to ping iocX but get no response. Need to look into receiver code?'
-- How to reboot things remotely
-- Triggers / TS stop updating on the GUI (but data seems to be coming in)
-- Triggers / TS stop updating from one of the VMEs?
Items for experimental setup/startup
-- How to better use the pulser
-- How to get a signal out of the digitizer for use as a scope
Data storage and processing
-- Stability and automation for disk mounting
-- understand the file writing with the gtReciever (max file size etc.)
-- How to transfer only data that is not on the mac already
-- Improved way to sum up the data runs
