DAQ system
This is an image map. Click on a section of the picture to go to the page for that item.
Gammasphere's DAQ system (data acquisition system) is now placed on relay racks by each side of its "hemispheres". Each of the racks for the DAQ consists of a power supply, a collector box, and a VME crate. The data acquisition system observes, interprets, and modifies data taken from Gammasphere and appropriately presents it to the user.
The picture above provides an overall map to the naming conventions associated with the system. Cardinal directions are shown in purple text, process variable (EPICS) names are shown in green text and network IDs are shown in red text. There are multiple computers within the DAQ system:
| Network name | IP address | Description |
| ioc01: | 192.168.203.141 | MVME5500 VME processor used for control and readout |
| ioc02: | 192.168.203.142 | MVME5500 VME processor used for control and readout |
| ioc03: | 192.168.203.143 | MVME5500 VME processor used for control and readout |
| ioc04: | 192.168.203.144 | MVME5500 VME processor used for control and readout |
| ioc05: | 192.168.203.145 | MVME5500 VME processor used for control and readout |
| ioc06: | 192.168.203.177 | MVME5500 VME processor used for control and readout |
| ioc07: | 192.168.203.178 | MVME5500 VME processor used for control and readout |
| ioc08: | 192.168.203.179 | MVME5500 VME processor used for control and readout |
| ioc09: | 192.168.203.180 | MVME5500 VME processor used for control and readout |
| ioc10: | 192.168.203.183 | MVME5500 VME processor used for control and readout |
| ioc11: | 192.168.203.181 | MVME5500 VME processor used for control and readout |
| ioc12: | 192.168.203.182 | MVME5500 VME processor used for control and readout |
| gs-cne | 192.168.203.88 | Raspberry Pi inside the North East Collector box |
| gs-cnw | 192.168.203.149 | Raspberry Pi inside the North West Collector box |
| gs-cse | 192.168.203.42 | Raspberry Pi inside the South East Collector box |
| gs-csw | 192.168.203.26 | Raspberry Pi inside the South West Collector box |
| gs-pdu-north | 192.168.203.224 | Power Distribution Unit for the North Hemisphere |
| gs-pdu_south | 192.168.203.225 | Power Distribution Unit for the North Hemisphere |
| gs-ts-north | 192.168.203.91 | Terminal server providing console port access for ioc07 through ioc12 |
| gs-ts_south | 192.168.203.186 | Terminal server providing console port access for ioc01 through ioc06 |
| lnfill | 192.168.203.121 | Embedded VME processor that hosts the EPICS databases for valve status and valve control |
| ln2con | 192.168.203.148 | Linux computer that lnfill boots from |
When Gammasphere collects data, single-ended signals are first collected from the slope box for the Ge Center, Ge Sides, and BGO segment. The signals are converted to differential signals by the SBX, and are then sent to the collector box so the signals can properly be routed to the digitizers. The digitizers process and output the desired information to the user based upon their data specifications. The DAQ system is an FPGA-based design that provides communication hub interfacing the preamp, power board, dongle and slope box to EPICS through serial interface. Analog signal paths are completely software controlled.
DAQ System Function
The Gammasphere DAQ system consists of VME crates, IOC Modules, Digitizers and Trigger Modules. The original "analog" implementation of Gammasphere using the VXI modules used a charge-integrating ADC methodology and did not continuously digitize the data from the detectors. The Digital Gammasphere system (2010s) introduced the digitizers as a replacement for the charge-integrating ADC functions of the VXI modules and replaces the "analog" system's trigger by a new trigger system, requiring a redesign of the DAQ. The later "Gammasphere Upgrade" project (2019-2023) that resulted in the SBX, preamp and collector box hardware did not materially affect the DAQ but replaced all of the remaining control, monitoring and power distribution functions of the VXI system allowing removal of the VXI system and associated cable plant.
Each digitizer in the system consists of 10 channels, but should be conceptualized as a pair of two sub-digitizers consisting of five channels each. There are two types of digitizers: master and slave. A pair of channels in a master digitizer receives signals from the Ge center and BGO sum from a single Gammasphere detector, while a channel-pair in the slave digitizer receives signals from the Ge side and BGO pattern. All channels in all digitizers run continuously. There are two types of digitizers (master and slave) as well as two types of triggers (master and router).
When discriminator logic within the digitizer firmware marks edges of gamma-ray signals, energy sums, timing and other data are stored in a header identifying the event. If the event is selected for readout by the trigger system, the header and a programmable amount of waveform is transferred from the channel to the board-wide FIFO (first in, first out) data holder. Similarly the trigger modules have FIFO buffers that store information each time a trigger acceptance message is issued to the digitizers. The IOC scans the FIFOs of all modules to see if there is data to read out through a series of programs named inLoop, outLoop and MiniSender. If data is available, the inLoop program reads it and stores the data read into memory buffers. Program outLoop verifies the integrity of the buffers and then hands control of the buffers to the MiniSender program. A separate program running on a different computer called “gtReceiver” sends messages to each IOC's MiniSender program when it is capable of receiving data. The MiniSender program of each IOC, in response to requests from gtReceiver, then breaks apart buffers into UDP packets and sends them to gtReceiver. The gtReceiver program then stores the data received to files that may be organized by digitizer or by channel.
To view how this system is controlled, go to DGS Commander EDM Screens.
Go back to Digital Gammasphere Upgrade Project
