Raspberry Pi camera use
To boot the raspberry pi up
connect cat6 cable to onenet switch (next to it) [connect monitor (HDMI)] [connect keyboard] [the wireless mouse should already be there] connect the usb power plug
It should then boot up and connect itself to onenet where it will have the IP
192.168.203.2
The pi user password is now the default DGS password, not the default pi one!!
Booting it up with the cat6 cable attached, is the easiest way to make sure it comes up on onenet. On some machines it can also be reached as darekpi02 if DNS is set up properly
To use the raspberry pi camera to stream data
sudo service motion stop ./motion -c motion-mmalcam-both.conf
that should start a little webserver so that you can see the live stream from a web browser as:
http://192.168.203.2:8081
You will have to be on onenet to see the the video stream.
When you want to stop the stream, simply type crtl-c in the window you started the stream in
To configure the raspberry pi to use the streaming software do
TBD [have history log file]
Thanks
Thanx to Kalle for setting up this system
