Raspberry Pi camera use
To boot the raspberry pi up,
connect cat6 cable to onenet switch (next to it) connect monitor (HDMI) connect keyboard the wireless mouse should already be there connect the usb power plug
It should then boot up and connect itself to onenet where it will have the IP
192.168.203.2
on some machines it can also be reached as darekpi02 if DNS is set up properly
To use the raspberry pi camera to stream data:
sudo service motion stop ./motion -c motion-mmalcam-both.conf
that should start a little webserver so that you can see the live stream from a web browser as:
http://192.168.203.2:8081
To configure the raspberry pi to use the streaming software do
TBD
When you want to stop the stream, simply type crtl-c in the window you started the stream in
