Operations
to start the DAQ
- The DAQ is running on machine "A1" (for now)
ssh -X [email protected]
- Go to the Gretina DAQ top level directory
gt cd 11-1/gretClust/bin/linux-x86
- Start the GRETINA DAQ MENU:
$PWD/godaq
- The MENU shows up:
---------- MENU ---------- VME 1 Display 2 Run Control 3 Run ControlBGS 3b Soft IOC 4 Soft IOC2 4b CAEN PS 5 Cluster 6 Cluster Kill 8 Mode 2 9 Mode 3 10 Mode 4 11 RESET daq InBeam 12 RESET daq Gamma 12b StripTool 13 Calibrate 14 EXIT E KILL ALL K
- Start elements in the following order:
4, 4b, 2, 3
verify "CA Connected" (CA: Channel Access) status in the RunControl panel
- Press Button "cluster" in the GlobalControl panel to chose the correct data mode (mode 2: decomposed data, mode 3: raw data (traces))
Note: In the Gretina RunControl panel, 'new dir' makes the run starts at 0002, switching back to an existing directory makes the run start at the previous Run number + 2
- Start the Cluster by typing "6" in the MENU
check cluster
- Press button "global control"
- The upcoming panel is being used for setting global parameters for ALL chrystals (baseline, polarity, etc.)
Raw delay: For internal mode data: 3.7 usec (for analyzing the traces) Raw len: length of the trace in usec don't go below 0.2 usec (corresponding to 20 short words, while the header is already 16 words long, so there are 4 words left for the trace itself) in decomposition mode: Use 2.0 usec (corresponding to 16 words for the header and 184 words for the trace)
- Press button "TimeStamps" in the Gretina DAQ top level to check if the timestamps are still synchronized
imp sync: starts a train of imperative sync signals, by pressing the button again, the train stops single pulse imp sync: One single imperative sync pulse
caput node0001_CS_Program1 sendRaw
caput node0001_CS_Program1 Decomp
to stop the DAQ
to shut down the DAQ
- Type 8 in the MENU to kill the Cluster
- Type K (Kill All) in the MENU to kill the rest
online sorting with GEBSort
[These instructions should be generalized]
Here is an example of running GEBSort on a1.gam on-line taking data from the GEB
1) Download and compile
cd workdir (e.g., cd d6/gretina/devel/cur) svn co https://svn.anl.gov/repos/gs_analysis . or wget http://www.phy.anl.gov/gretina/GEBSort/AAAtar.tgz tar -zxvf AAAtar.tgz rm curEPICS; ln -s /global/devel/base/R3.14.11 curEPICS export ROOTSYS=/home/users/tl/root/root-v5-34-00 export PATH=$ROOTSYS/bin:$PATH export LD_LIBRARY_PATH=/home/users/tl/root/root-v5-34-00/lib/root make GEBSort
2) to run and take data, type
./GEBSort -input geb 10.0.1.100 100 0 100.0 RECREATE \ -chat GEBSort.chat \ -rootfile test.root &
3) to stop the on-line sort and write the root file out, type
./stop.sh
4) to display the data
root-l compile GSUtils load root file display
