Operations
Jump to navigation
Jump to search
to start the DAQ
ssh -X gretina@a1.gam
gt
cd 11-1/gretClust/bin/linux-x86
$PWD/godaq
4
4b
2
3
verify "CA Connected" status "cluster" (new dir makes the run starts at 2) 6 check cluster "global control" imp sync
caput node0001_CS_Program1 sendRaw caput node0001_CS_Program1 Decomp
to stop the DAQ
online sorting with GEBSort
[These instructions should be generalized]
Here is an example of running GEBSort on a1.gam on-line taking data from the GEB
1) Download and compile
cd workdir (e.g., cd d6/gretina/devel/cur) svn co https://svn.anl.gov/repos/gs_analysis . or wget http://www.phy.anl.gov/gretina/GEBSort/AAAtar.tgz tar -zxvf AAAtar.tgz rm curEPICS; ln -s /global/devel/base/R3.14.11 curEPICS export ROOTSYS=/home/users/tl/root/root-v5-34-00 export PATH=$ROOTSYS/bin:$PATH export LD_LIBRARY_PATH=/home/users/tl/root/root-v5-34-00/lib/root make GEBSort
2) to run and take data, type
./GEBSort -input geb 10.0.1.100 100 0 100.0 RECREATE \ -chat GEBSort.chat \ -rootfile test.root &
3) to stop the on-line sort and write the root file out, type
./stop.sh
4) to display the data
root-l compile GSUtils load root file display
