Operations
From GRETINA at ANL
Revision as of 15:27, July 26, 2013 by Tlauritsen (talk | contribs)
to start the DAQ
ssh -X [email protected] gt cd 11-1/gretClust/bin/linux-x86 $PWD/godaq 4 4b 2 3 verify "CA Connected" status "cluster" (new dir makes the run starts at 2) 6 check cluster "global control" imp sync
caput node0001_CS_Program1 sendRaw caput node0001_CS_Program1 Decomp
to stop the DAQ
online sorting with GEBSort
[These instructions should be generalized]
Here is an example of running GEBSort on a1.gam on-line taking data from the GEB
1) Download and compile
 cd workdir (e.g., cd d6/gretina/devel/cur)
   svn co https://svn.anl.gov/repos/gs_analysis .
 or
   wget http://www.phy.anl.gov/gretina/GEBSort/AAAtar.tgz
   tar -zxvf AAAtar.tgz
 rm curEPICS; ln -s /global/devel/base/R3.14.11 curEPICS
 export ROOTSYS=/home/users/tl/root/root-v5-34-00
 export PATH=$ROOTSYS/bin:$PATH
 export LD_LIBRARY_PATH=/home/users/tl/root/root-v5-34-00/lib/root
 make GEBSort
2) to run and take data, type
  ./GEBSort -input geb  10.0.1.100    100 0 100.0 RECREATE \
  -chat GEBSort.chat \
  -rootfile test.root &
3) to stop the on-line sort and write the root file out, type
 ./stop.sh
4) to display the data
 root-l
 compile GSUtils
 load root file
 display
FAQ
