Network
From GRETINA at ANL
Revision as of 19:15, June 11, 2013 by Tlauritsen (talk | contribs) (Created page with "==The GRETINA network== The decomposition cluster is located in g126 and has a 10GBit fiber optics link to area 4 where the digitizer racks are located. There is a 1GBit fibe...")
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
The GRETINA network
The decomposition cluster is located in g126 and has a 10GBit fiber optics link to area 4 where the digitizer racks are located. There is a 1GBit fiber optics link from g126 to the data room as well. The NAT box that defines private network, gt1.anl.gov, is located in g126. The gretina 10.0.x.x network is separate from onenet.
Access from outside to the GRETINA network
You can access the the GRETINA private network through the NAT box that defines private network, gt1.anl.gov. You will be port-forwarded to a linux box called 'TBD'. For accounts on this linux box (and thereby access to the GRETINA private network), send an Email to [email protected]. Once you have ssh'ed to this machine, you can ssh from there to any of the other GRETINA nodes. There are no outsideIP-to-insideIP connections directly to GRETINA nodes as it was done at MSU.
