Nanofabrication/Photoresist
From CNM Wiki
< Nanofabrication
Revision as of 19:10, November 24, 2020 by Csmiller (talk | contribs)
Kayakuam :[1] is the supplier of our Shipley 1800's, MicroResist Technology, SU8, LOR, SPR, and PMMA photoresists, developers, and strippers.
ZEON :ZEON is the supplier of our ZEP photoresists
Resist Name Photoresist Type Tk/Flavor Developer Strippers Optical (MA6, Stepper) Laser Writer EBEAM Lith. (JEOL, RAITH) Process Data Sheet
1800 Series positive 1805, 1813, 1818 351 Dev: H20 (1:4) ratios can vary Acetone/IPA or 1165 yes yes https://kayakuam.com/wp-content/uploads/2019/09/S1800-G2.pdf
AZ P4620 positive 1700 - 2600 nm 351 Dev: H20 (1:4) ratios can vary Acetone/IPA or 1165 yes yes
SPR 220 series positive 3, 7 i-line photoresist CD26 Acetone/IPA or 1165 yes yes https://kayakuam.com/wp-content/uploads/2019/10/SPR_220_DATA_SHEET_RH.pdf
SPR 955-CM Series positive nm CD26 Acetone/IPA or 1165 yes yes(MLA) https://kayakuam.com/products/megaposit-spr955-cm-series-high-resolution-i-line-photoresists/
LOR 3A, 30B positive nm CD26 Acetone/IPA or 1165 yes yes https://kayakuam.com/wp-content/uploads/2019/09/KAM-LOR-PMGI-Data-Sheet-11719.pdf
AZ nLOF 2000 negative 351 Dev: H20 (1:3) ratios can vary Acetone/IPA or 1165 yes
ma-N 1400 negative Ma-D 355 Acetone/IPA or 1165 yes
SU8 negative SU8 Developer Acetone/IPA or 1165 yes yes (MLA) yes https://kayakuam.com/wp-content/uploads/2020/09/KAM-SU-8-2-25-Datasheet-9.3.20-final.pdf%7C
SU8 3000 negative SU8 Developer Acetone/IPA or 1165 yes yes (MLA) yes
ZEP positive MIBK: IPA 1:3 Acetone/IPA or 1165 yes
PMMA 495 positive A2, A3 MIBK: IPA 1:3 Acetone/IPA or 1165 yes https://kayakuam.com/wp-content/uploads/2019/09/PMMA_Data_Sheet.pdf%7C
PMMA 950 positive A2, A3, A4, A8, A11 MIBK: IPA 1:3 Acetone/IPA or 1165 yes https://kayakuam.com/wp-content/uploads/2019/09/PMMA_Data_Sheet.pdf%7C
