HPC/Network Access/PuTTY Configuration
From CNM Wiki
Revision as of 21:26, June 26, 2019 by Stern (talk | contribs)
The Carbon cluster is reachable from networks outside Argonne only through SSH tunneling or VPN. Either way has advantages and disadvantages. This page explains how to connect through an ssh tunnel.
Configuring
The following steps need to be performed once for each workstation you wish to use to access Carbon.
Connecting
To connect to Carbon for interactive work, or to access its networked licenses, perform a preparatory step, needed only once for a given Windows login session.
From then on, and while the preparatory window remains active, connect as often as desired.
File Transfers
  1. Configure your PuTTY installation as shown above.
  2. Connect to the SSH Gateway, as shown in the preceeding section.
  3. Open the psftp application, and select the clogin PuTTY profile to connect to.
