HPC/Applications/lammps
Binaries
Several LAMMPS binaries are provided by the LAMMPS module, giving you options to run with MPI and/or a couple of GPU packages. Earlier modules only contained one MPI binary. Binaries compiled with GPU support will not run on nodes without a GPU (CUDA libraries are deliberately only installed on GPU nodes.) Moreover, a binary built with the USER-CUDA package will attempt to access the GPU by default [1].
| Binary name | Description |
lmp_openmpi-main |
The baseline binary, containing the packages shown by module help lammps.
lmp_openmpi |
The distribution's default name; synonym for lmp_openmpi-main;
lmp_openmpi-gpu |
The package "gpu" and all packages from main. |
lmp_openmpi-user-cuda |
The package "user-cuda" and all packages from main. |
lmp_openmpi-jr |
A custom build for user J.R. |
To use the *-gpu and *=user-cuda binaries, load the cuda module in addition to lammps.
module load cuda module load lammps
To use any one of the binaries, simply name the appropriate one in the job file; full paths are neither necessary nor recommended.
Library linking
- Consult the LAMMPS documentation
- Carbon-specifics: To point your compiler and linker to the installed LAMMPS module, always use the environment variable
$LAMMPS_HOME, never full path names. Edit the makefile of your application and add settings similar to the following:
CPPFLAGS += -I${LAMMPS_HOME}/include
FPPFLAGS += -I${LAMMPS_HOME}/include
LDFLAGS += -L$(FFTW3_HOME) -L${LAMMPS_HOME}/lib -llammps -lfftw3 -limf
- These settings refer to variables customarily used in makefiles for GNU Make. Your package might use different variables. Adapt as needed.
- The
-llammpsprovides the same LAMMPS optional packages as the main binary, and supports MPI and OpenMP. It is actually equivalent to using:
-llammps_mpi-main
- This variant is available for both static (*.a) and dynamic (*.so) linkage but supports no GPUs.
- To use GPU nodes, link with one of the following instead:
-llammps_mpi-gpu -llammps_mpi-user-cuda
- These variants are only available for static linkage.
Inspect a sample code that uses LAMMPS as a library at:
cd ${LAMMPS_HOME}/src/examples/COUPLE/simple
cat Makefile
GPU support
LAMMPS offers two different packages for using GPUs, one official, the other user-contributed. Only one of these packges can be used for a run. The packages are fully documented in the following sections of the LAMMPS manual:
To use LAMMPS with GPUs on Carbon you must read and understand these sections. A summary and Carbon-specific details are given in the next section.
Using GPU packages
- HPC/Applications/lammps/Package GPU
- HPC/Applications/lammps/Package USER-CUDA
- HPC/Applications/lammps/Package OMP – if you really want to.
Jobs on Carbon
For sample PBS scripts, consult these files:
$LAMMPS_HOME/sample.job $LAMMPS_HOME/sample-hybrid.job
Benchmark (pre-GPU version)
Using a sample workload from Sanket ("run9"), I tested various OpenMPI options on node types gen1 and gen2.
LAMMPS performs best on gen2 nodes without extra options, and pretty well on gen1 nodes over ethernet(!).
| Job tag | Node type | Interconnect | Additional OpenMPI options | Relative speed (1000 steps/3 hours) |
Notes |
| gen1 | gen1 | IB | (none) | 36 | |
| gen1srqpin | gen1 | IB | -mca btl_openib_use_srq 1 -mca mpi_paffinity_alone 1 |
39 | |
| gen1eth | gen1 | Ethernet | -mca btl self,tcp | 44 | fastest for gen1 |
| gen2eth | gen2 | Ethernet | -mca btl self,tcp | 49 | |
| gen2srq | gen2 | IB | -mca btl_openib_use_srq 1 | 59 | |
| gen2 | gen2 | IB | (none) | 59 | fastest for gen2 |
Diagnostic for hybrid parallel runs
- LAMMPS echoes it parallelization scheme first thing in the output:
LAMMPS (10 Feb 2012) using 4 OpenMP thread(s) per MPI task ... 1 by 2 by 2 MPI processor grid 104 atoms ...
and near the end:
Loop time of 124.809 on 16 procs (4 MPI x 4 OpenMP) for 30000 steps with 104 atoms
- To see if OpenMP is really active, log into a compute node while a job is running and run
toporpsuser– The%CPUfield should be aboutOMP_NUM_THREADS × 100%
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 8047 stern 25 0 4017m 33m 7540 R 401.8 0.1 1:41.60 lmp_openmpi 8044 stern 25 0 4017m 33m 7540 R 399.9 0.1 1:43.50 lmp_openmpi 4822 root 34 19 0 0 0 S 2.0 0.0 115:34.98 kipmi0
References
- HPC/Submitting_Jobs/Advanced node selection#Multithreading (OpenMP)
- LAMMPS documentation for the OMP package
- Command-line options (explanation for -sf style or -suffix style)
