HPC/Module Setup
From CNM Wiki
< HPC
Revision as of 21:50, September 12, 2013 by Stern (talk | contribs) (Test)
 Introduction
Carbon uses the Environment Modules package to dynamically provision software. The package primarily modifies your $PATH and other environment variables.
To select packages for your use, place module load name commands near the end of your ~/.bashrc file.
The Shell
The user shell on Carbon is bash.
A note on tcsh for long-time Unix/Linux users
[t]csh used to be the only vendor-agnostic and widely available shell with decent command line features. Bash is now much better positioned in this area, and offers consistent programming on the command line and in scripts. Therefore, tcsh is now available only on request (to me, stern), if you absolutely, positively, insist, and know what you're doing. (There will be a quiz.)
There are good reasons not to use the C shell, and classic wisdom states “csh programming considered harmful”. Even though using [t]csh merely for interactive purposes may appear tolerable, it is too tempting to set out from tweaking .cshrc into serious programming. Don't do it. It is not supported. It's dead, Jim.
  • Do not use chsh or chfn. Changes will be overwritten.
Shell Customizations
Place customizations in your ~/.bashrc file by using a text editor such as nano. A pristine copy is shown below, or can be found at /etc/skel/.bashrc
# ~/.bashrc
# User's bash customization, Carbon template; stern 2011-09-15.
# Merge global definitions -- do not edit.
if [ -f /etc/bashrc ]; then
    . /etc/bashrc
fi
# Carbon customizations -- edit below.
export PATH=$HOME/bin:$PATH
#alias blah="foo -xyz"
#module load ...
  • For instance, to add binaries from a user's own compilation of somepackage, and load a couple of modules:
export PATH=$HOME/somepackage/bin:$HOME/bin:$PATH
module load name1 name2
Test
To test the impact of any changes, temporarily run a new shell:
bash -l        # lowercase letter L
# run other shell commands
# back to the original login shell
echo $SHLVL
exit
  • Make further corrections to ~/.bashrc as needed.
  • You might get lost in multiple nested shell levels. To see the current nesting level, inspect the environment variable $SHLVL as shown above. A normal login shell runs at level 1.
Pick up newly added modules
When all looks good, either:
  • simply restart your shell in place:
exec bash -l
bash is followed by an option of a lowercase letter "L".
  • Alternatively, log out and back in, which is a bit more involved.
Caveats
  • Among the various bash startup files .bashrc is the one relevant when invoked remotely, such as on MPI child nodes reached by sshd.
  • In general, do not place a "module load …" command in a PBS job script.
    • This will only work reliably for single-node jobs.
    • It will generally fail for multi-node jobs (nodes > 1).
      Reason: The job script is only executed (by the pbs_mom daemon on your behalf) on the first core on the first node of your request. The environment of this process will be cloned for the other cores on the first node, but not for cores on other nodes. How remote environments are configured depends on the MPI implementation. The various mpirun or mpiexec offer flags to pass some or all environment variables to other MPI processes, but these flags are implementation-specific and may not work reliably.
  • The most reliable and recommended way is as above, to place module commands in ~/.bashrc. This might preclude job-specific module sets for conflicting modules or tasks. I'm thinking about a proper solution for this. --stern
Modules – General documentation
  • A general introduction to modules can be found at many other sites, such as:
$ module help
  Usage: module [ switches ] [ subcommand ] [subcommand-args ]
  Available SubCommands and Args:
+ load		modulefile [modulefile ...]
+ unload	modulefile [modulefile ...]
+ switch	[modulefile1] modulefile2.]
+ list
+ avail		[modulefile [modulefile ...]]
+ whatis	[modulefile [modulefile ...]]
+ help		[modulefile [modulefile ...]]
+ show		modulefile [modulefile ..]
For full documentation, consult the manual page:
$ man module
Module Conventions on Carbon
  • Most application software is installed under /opt/soft
  • Package directories are named name-version-build , e.g. /opt/soft/jmol-12.1.37-1.
  • Module names are organized by a mostly version-less name, with the version following after a slash: name/version-build . Using the name component alone is possible and will select a default version for module subcommand to act upon. Some packages do carry a major version number in their name, notably fftw3 and vasp5.
  • module help briefly describes a package, gives its version number (in the module path) and will usually contain a link to its home page.
$ module help jmol
----------- Module Specific Help for 'jmol/12.0.34-1' -------------
	Jmol is a molecule viewer platform for researchers in chemistry and
	biochemistry, implemented in Java for multi-platform use.  This is the
	standalone application.  It offers high-performance 3D rendering with
	no hardware requirements and supports many popular file formats.
	http://jmol.sourceforge.net/
	http://wiki.jmol.org/
  • Default modules are loaded by /etc/profile.d/zz-moduleuse.sh. (The strange name form ensures this profile segment is loaded last.) They currently are:
$ module list
Currently Loaded Modulefiles:
  1) moab/6.0.3-1              4) icc/11/11.1.073
  2) gold/2.1.11.0-4           5) ifort/11/11.1.073
  3) openmpi/1.4.3-intel11-1   6) mkl/10.2.6.038
Package home directory organization
A package directory usually contains Unix-style subdirectories for the various files, which the modulefile usually automatically integrates into your user environment by means of standard environment variables.
bin/
the main package executable and associated tools and utility scripts; added to $PATH.
lib/
static and shared libraries; added to $LD_LIBRARY_PATH if it contains shared libs.
man/, share/man/, doc/, share/doc/
man pages (added to $MANPATH) and human-readable documentation.
include/
C header files and other script integration files for using library packages; added to $INCLUDE.
and others.
Environment variable for package home directory
Most modules will set a convenience variable $NAME_HOME which points to the package's toplevel directory. Dashes in the package name are converted to underscores in the environment variable. This is a convention on Carbon.
This convention is mostly useful to inspect documentation and auxiliary files of a package:
$ module load quantum-espresso
 $ ls -F $QUANTUM_ESPRESSO_HOME/doc
 Doc/  atomic_doc/  examples/
… and to specifcy link paths in makefiles:
$ module load fftw3
 LDFLAGS += -L$(FFTW3_HOME)/lib
Package-specific sample job
Packages that require more than the standard Carbon job template contain a sample job in the toplevel directory:
cat $QUANTUM_ESPRESSO_HOME/*.job
which gives:
#!/bin/bash
# Job template for Quantum ESPRESSO 4.x on Carbon
#PBS -l nodes=1:ppn=8
#PBS -l walltime=1:00:00
#PBS -N qe_jobname
#PBS -A cnm12345
# Output and error log:
#PBS -o job.out
#PBS -e job.err
## send mail at begin, end, abort, or never (b, e, a, n):
#PBS -m ea
cd $PBS_O_WORKDIR
# job-specific tmp directories -- each is node-local, wiped on exit
export ESPRESSO_TMPDIR=$TMPDIR
mpirun -x ESPRESSO_TMPDIR \
	-machinefile  $PBS_NODEFILE \
	-np $(wc -l < $PBS_NODEFILE) \
	pw.x \
	< input.txt > output.txt
