HPC/Applications/atk/License configuration on Windows
From CNM Wiki
< HPC‎ | Applications‎ | atk
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
  1. Locate and start atk_license_setup.exe, typically located in C:\"Program Files (x86)"\QuantumWise\atk-12.2.2\license\atk_license_config.exe
  2. Push Next.
  3. You will see the current license configuration. Push OK.
  4. Choose the Floating option and push Next.
  5. As License server address, enter this exact string (with semicolons ";" and "@" characters, no spaces):
    localhost;6201@localhost
    Note: The license server string will be assigned to the environment variable QUANTUM_LICENSE_PATH. As of ATK-12.2.2, the characters 6200@ will be automatically prepended to the variable. Do not enter a numeric value before the first host name in the License server field above.
  6. Push Next.
  7. Push Next again.
  8. Push Finish.
