HPC/Applications/atk
From CNM Wiki
Revision as of 22:11, October 25, 2012 by Stern (talk | contribs)
Parallel jobs
Local changes
  • We use Intel-MPI instead of MPICH2, with the Hydra process manager instead of MPD. See the sample.job file for details:
$ATK_HOME/sample.job
The atk module loads impi in the background, then openmpi again. This trick exposes mpiexec.hydra from Intel-MPI, whereas all other MPI commands continue to refer to OpenMPI.
Co-loading ATK and VASP modules
This module needs MPICH2 libraries (happily provided by Intel-MPI), and hence clashes with VASP, which uses HPC/Applications/openmpi.
Co-existence is possible as follows:
module unload openmpi
module load atk
module load openmpi
module load vasp5      # … or other versions
Remote access from Windows
  1. Install ATK on your machine.
  2. You will need an ATK license to run VNL or atpkypthon. Choose one of the following to remotely access Carbon's licenses:
    1. Basic: Set up license forwarding using PuTTY.
    2. Advanced: Set up license forwarding using Cygwin.
  3. Configure ATK to use forwarded licenses.
To connect:
  1. Follow section Connecting to reach clogin.
  2. Start VNL or atkpython normally on your machine.
  3. Troubleshoot ATK licensing.
