HPC/Network Access/Virtual Desktop
From CNM Wiki
Revision as of 01:21, October 5, 2012 by Stern (talk | contribs) (Tips)
Introduction
VNC is a multi-platform graphical remote access mechanism. It is not as common as the X Window System but is more light-weight on the user side and over the network. If you find that remote use over X11 is too slow, try VNC.
Principle of operation
  • Start a VNC server on a Carbon node. This is an application that will run under your user ID in the background and provide a virtual desktop for you.
  • Modify your SSH connection to forward an appropriate port.
  • Run a VNC client on your desktop machine and tell it to connect to the forwarded port. This will show the virtual desktop as a window on your actual desktop.
  • You can stop the VNC client and reconnect later.
  • When done, kill the VNC server process on Carbon.
VNC server startup
  • [Log in to Carbon] as documented.
  • On the clogin prompt (showing login5 or login6), enter:
vncserver
  • You may be asked for a password which will control access to a virtual desktop session. Choose and remember a password of good strength, but not your login password. The VNC password mechanism is weak; think of it as an office door to shut, keeping out unwanted guests.
  • To reset your password at any time, run:
vncpasswd
  • Obtain the display number from the output of the vncserver command:
New 'login5:1 (stern)' desktop is login5:1
Starting applications specified in /home/stern/.vnc/xstartup
Log file is /home/stern/.vnc/login5:1.log
The display number is shown after the : in the virtual desktop address, the last word in the first line.
Forward SSH ports
Forward a (TCP) port from your machine to the same port on the Carbon login node. How to do that depends on the SSH program you use, and which port to forward depends on the display number.
For Linux and Mac
  • Press <Enter>~C (three keys in succession: Enter, tilde, capital C). You should get a prompt like this:
ssh>
  • At the prompt, enter:
-L port:localhost:port
where port = 5900 + display number (from above), for example:
ssh> -L 5901:localhost:5901
Forwarding port.
  • Press <Enter> to regain your regular prompt.
For PuTTY on Windows
TBD
Connect to a session
On a Mac
  • Select Connect to Server… from the Finder's menu, or press Command + K.
  • Enter the Server Address in the form vnc://localhost:displaynum/ and push Connect.
  • You will get a warning that the connection is insecure. This warning pertains only to an internal connection between your SSH-forwarded port and vncserver. Your main remote connection from your own desktop to clogin will continue to be encrypted over the SSH channel.
  • Enter the VNC password you chose earlier.
  • You wil obtain a fairly basic virtual desktop with an xterm window running. The desktop is deliberately kept simple to reduce overhead and startup times.
Note: The screen shots were taken from a Mac running OS X version 10.8.2; Screen Sharing under other OS X versions will look and behave slightly differently.
Tips
Customizing the virtual desktop
  • Override the size and color depth of the virtual desktop by supplying options to vncserver:
vncserver -geometry 1920x1080 -depth 24
These options will raise your network bandwidth requirements. For more, see
man vncserver
Screen Sharing on the Mac
  • Recent Screen Sharing versions will pass through almost all keyboard input, which effectively disables many regular OS X keyboard shortcuts.
  • To take a screen shot, select Save Screen Capture As… from the Screen Sharing application menu.
  • To take screen shots more easily and show various other control optiosn, choose Show Toolbar from the Screen Sharing application menu.
VNC server teardown
On a Carbon login node, enter:
vncserver -kill :displaynumber
Troubleshooting
  • To see a list of recent VNC servers that you might be running:
ls -ltr ~/.vnc/*.pid
  • Identify and inspect server log files:
ls -ltr ~/.vnc/*.log
cat ~/.vnc/$HOSTNAME:displaynum.log
  • You can simply and unceremoniously kill all vncservers on a given host by using the Unix kill command. For good measure, run it twice, then clean up:
kill `cat ~/.vnc/$HOSTNAME*.pid`
rm ~/.vnc/$HOSTNAME*.pid
Please practice good housekeeping and do not needlessly leave vncserver processes running.
