HPC/Network Access/Virtual Desktop
< HPC | Network Access
Introduction
VNC is a multi-platform graphical remote access mechanism. It is not as common as the X Window System but is more light-weight on the user side and over the network. If you find that remote use over X11 is too slow, try VNC.
Principle of operation
- Start a VNC server on a Carbon node. This is an application that will run in the background and provide a virtual desktop.
- Modify your SSH connection to forward an appropriate port.
- Run a VNC client on your desktop machine and tell it to connect to the forwarded port. This will show the virtual desktop as a window on your actual desktop.
- You can stop the VNC client and reconnect later.
- When done, kill the VNC server process on Carbon.
VNC server startup
- [Log in to Carbon] as documented.
- On the clogin prompt (showing login5 or login6), enter:
vncserver
- You may be asked for a password which will control access to a virtual desktop session. Choose and remember a password of good strength, but not your login password. The VNC password mechanism is weak; think of it as an office door to shut, keeping out unwanted guests.
- To reset your password at any time, run:
vncpasswd
- Note the output of the vncserver command:
New 'login5:1 (stern)' desktop is login5:1 Starting applications specified in /home/stern/.vnc/xstartup Log file is /home/stern/.vnc/login5:1.log
The number after the : is the display number of your virtual desktop.
Forward SSH ports
Forward a (TCP) port from your machine to the same port on the Carbon login node. How to do that depends on the SSH program you use.
- For Linux and Mac
- Press
<Enter>~C(three keys in succession: Enter, tilde, capital C). You should get a prompt like this:
ssh>
- At the prompt, enter:
-L port:localhost:port
- where
port= 5900 + displaynumber from above, for example:
ssh> -L 5901:localhost:5901 Forwarding port.
- Press
<Enter>to regain your regular prompt.
- For PuTTY on Windows
- TBD
VNC server teardown
vncserver -kill :displaynumber
