HPC/Network Access/PuTTY Configuration/Accessing Carbon licenses remotely
Jump to navigation
Jump to search
Begin adding tunnels
- In the main PuTTY Configuration window, click Session at the top of the tree on the left.
- Select the Clogin session and push Load.
- Verify that the name "localhost" appeared in the Host Name field above. Go back to step 1 if it does not.
- Click "+" in front of SSH in the tree.
- Click Tunnels.
- If your session has existing tunnels and you wish to start over:
- Select each existing entry in the "Forwarded ports:" field and push Remove.
- No forwarded ports should remain at this point.
Add tunnels for VNL
- Under Add new forwarded port, enter:
- Source port: 6200
- Destination: mgmt03:6200
- Push Add.
- Repeat with the following settings:
- Source port: 6201 (not 6200!)
- Destination: mgmt04:6200
- Push Add.
- You should now see these two entries:
Add tunnels for COMSOL
Follow steps similar to VNL shown above. Use the following port numbers and host names:
| Source Port | Destination | Options |
| 1719 | mgmt03:1719 | Local, Auto |
| 33317 | mgmt03:1718 | Local, Auto |
| 33318 | mgmt04:1718 | Local, Auto |
| 33319 | sched1:1718 | Local, Auto |
- Because no port number is the same between VNL and COMSOL, their tunnel configurations can coexist.
Finish adding tunnels
- Scroll to the top of the tree and click Session.
- Verify that "Clogin" shows in the Saved Sessions field. If it does not, go back to section #Begin adding tunnels.
- Push Save.
