HPC/Network Access/PuTTY Configuration
From CNM Wiki
The Carbon cluster is reachable from networks outside Argonne only through SSH tunneling or VPN. Either way has advantages and disadvantages. This page explains how to connect through an ssh tunnel.
Configuring
The following steps need to be performed once for each workstation you wish to use to access Carbon.
Connecting
To connect to Carbon, perform a preparatory step, needed only once for a given Windows login session.
From then on, and while the preparatory window remains active, connect as often as desired.
