HPC/Module Setup
Introduction
Carbon uses the Environment Modules package to dynamically provision software. The package primarily modifies your $PATH and other environment variables.
To select packages for your use, place module load name commands near the end of your ~/.bashrc file.
The Shell
The user shell on Carbon is bash.
Documentation
A note on tcsh for long-time Unix/Linux users
[t]csh used to be the only vendor-agnostic and widely available shell with decent command line features. Bash is now much better positioned in this area, and offers consistent programming on the command line and in scripts. Therefore, tcsh is now available only on request (to me, stern), if you absolutely, positively, insist, and know what you're doing. (There will be a quiz.) Here are top ten reasons not to use the C shell, and the ever classic “csh programming considered harmful”. Even though using [t]csh merely for interactive purposes may appear tolerable, it is too tempting to set out from tweaking .cshrc into serious programming. Don't do it. It is not supported. It's dead, Jim.
- Do not use
chsh. Changes will be overwritten.
Shell Customizations
Place customizations in your ~/.bashrc file. A pristine copy is shown below, or can be found at /etc/skel/.bashrc
# ~/.bashrc
# User's bash customization, Carbon template; stern 2011-09-15.
# Merge global definitions -- do not edit.
if [ -f /etc/bashrc ]; then
. /etc/bashrc
fi
# Carbon customizations -- edit below.
export PATH=$HOME/bin:$PATH
#alias blah="foo -xyz"
#module load ...
- For instance, to add binaries from a user's own compilation of
somepackage, and load a couple of modules:
export PATH=$HOME/somepackage/bin:$HOME/bin:$PATH
module load name1 name2 …
To test major changes, temporarily run a new shell. Inspect the environment variable $SHLVL to see the shell nesting level.
echo $SHLVL
bash -l # lowercase letter L
echo $SHLVL
# run other regular commands
# back to the original login shell
exit
When all looks good, either log out and back in, or simply restart your login shell process in place (rather than as a child command):
exec bash -l
- Among the various bash startup files .bashrc is the one relevant when invoked remotely, such as on MPI child nodes reached by sshd.
- In general, do not place a
"module load …"command in a PBS job script.
- If you must, note that this command will only work for single-node jobs. It will generally fail for multi-node jobs (nodes > 1). The reason is that the job script is only executed (by the
pbs_momdaemon on your behalf) on the first core on the first node of your request. In general, this environment will be cloned for the other cores on the first node, but not for cores on other nodes. There are flags formpirunormpiexecto pass some or all environment variables to other MPI processes, but these flags are implementation-specific and may not work reliably.
- The recommended way is as above, to place module commands in ~/.bashrc. This might preclude job-specific module sets for conflicting modules or tasks. I'm thinking about a proper solution for this. --stern
Modules – General documentation
$ module help … Usage: module [ switches ] [ subcommand ] [subcommand-args ] … Available SubCommands and Args: + load modulefile [modulefile ...] + unload modulefile [modulefile ...] + switch [modulefile1] modulefile2.] + list + avail [modulefile [modulefile ...]] + whatis [modulefile [modulefile ...]] + help [modulefile [modulefile ...]] + show modulefile [modulefile ..]
For full documentation, consult the manual page:
$ man module
Module Conventions on Carbon
- Most application software is installed under
/opt/soft - Package directories are named
name-version-build, e.g./opt/soft/jmol-12.1.37-1. - Module names are organized by a mostly version-less name, with the version following after a slash:
name/version-build. Using thenamecomponent alone is possible and will select a default version for a SubCommand to act upon. Some packages carry a major version number in their name, notably fftw3 and vasp5. module helpbriefly describes a package, gives its version number (in the module path) and will usually contain a link to its home page.
$ module help jmol ----------- Module Specific Help for 'jmol/12.0.34-1' ------------- Jmol is a molecule viewer platform for researchers in chemistry and biochemistry, implemented in Java for multi-platform use. This is the standalone application. It offers high-performance 3D rendering with no hardware requirements and supports many popular file formats. http://jmol.sourceforge.net/ http://wiki.jmol.org/
- Default modules are loaded by
/etc/profile.d/zz-moduleuse.sh. (The strange name form ensures this profile segment is loaded last.) They currently are:
$ module list Currently Loaded Modulefiles: 1) moab/6.0.3-1 4) icc/11/11.1.073 2) gold/2.1.11.0-4 5) ifort/11/11.1.073 3) openmpi/1.4.3-intel11-1 6) mkl/10.2.6.038
Package home directories
A package directory usually contains Unix-style subdirectories for the various files, which the modulefile usually automatically integrates into your user environment by means of standard environment variables.
bin/- the main package executable and associated tools and utility scripts; added to
$PATH. lib/- static and shared libraries; added to
$LD_LIBRARY_PATHif it contains shared libs. man/, share/man/, doc/, share/doc/- man pages (added to
$MANPATH) and human-readable documentation. include/- C header files and other script integration files for using library packages; added to
$INCLUDE. - … and others.
Further, most modules will set a convenience variable $NAME_HOME which points to the toplevel directory. Dashes in the package name are converted to underscores. This is mostly useful to inspect documentation and auxiliary files:
$ module load quantum-espresso
$ ls -F $QUANTUM_ESPRESSO_HOME/doc
Doc/ atomic_doc/ examples/
- … and to specifcy link paths in makefiles:
$ module load fftw3
LDFLAGS += -L$(FFTW3_HOME)/lib
Package-specific sample jobs
Packages that require more than the standard Carbon job template contain a sample job in the toplevel directory:
cat $QUANTUM_ESPRESSO_HOME/*.job
which gives:
#!/bin/bash
# Job template for Quantum ESPRESSO 4.x on Carbon
#PBS -l nodes=1:ppn=8
#PBS -l walltime=1:00:00
#PBS -N qe_jobname
#PBS -A cnm12345
# Output and error log:
#PBS -o job.out
#PBS -e job.err
## send mail at begin, end, abort, or never (b, e, a, n):
#PBS -m ea
cd $PBS_O_WORKDIR
# job-specific tmp directories -- each is node-local, wiped on exit
export ESPRESSO_TMPDIR=$TMPDIR
mpirun -x ESPRESSO_TMPDIR \
-machinefile $PBS_NODEFILE \
-np $(wc -l < $PBS_NODEFILE) \
pw.x \
< input.txt > output.txt
