Here is a sample job script for an MPI application in the default user environment (OpenMPI over Infiniband interconnect):
#!/bin/bash## Basics: Number of nodes, processors per node (ppn), and walltime (hhh:mm:ss)#PBS -l nodes=5:ppn=8#PBS -l walltime=0:10:00#PBS -N job_name#PBS -A account## File names for stdout and stderr. If not set here, the defaults## are <JOBNAME>.o<JOBNUM> and <JOBNAME>.e<JOBNUM>#PBS -o job.out#PBS -e job.err## send mail at begin, end, abort, or never (b, e, a, n)#PBS -m ea# change into the directory where qsub will be executedcd$PBS_O_WORKDIR# count allocated coresnprocs=$(wc-l<$PBS_NODEFILE)# start MPI job over default interconnect
mpirun-machinefile$PBS_NODEFILE-np$nprocs\programname
If your program reads from files or takes options and/or arguments, use and adjust one of the following forms:
In the last form, anything after programname is optional. If you use specific redirections for stdout or stderr as shown (>, 2>), the job-global files job.out, job.err declared earlier will remain empty or only contain output from your shell startup files (which should really be silent), and the rest of your job script.
Infiniband (OpenIB) is the default (and fast) interconnect mechanism for MPI jobs. This is configured through the environment variable $OMPI_MCA_btl.
To select ethernet transport (e.g. for embarrasingly parallel jobs), specify an -mca option:
The parameter for option -A account is in most cases the CNM proposal, specified as follows:
cnm123
(3 digits) for proposals below 1000
cnm01234
(5 digits, 0-padded) for proposals from 1000 onwards.
user
(the actual string "user", not your user name) for a limited personal startup allocation
staff
for discretionary access by staff.
You can check your account balance in hours as follows:
mybalance-h
gbalance-u$USER-h
Advanced node selection
You can refine the node selection (normally done via the PBS resource -l nodes=…) to
finely control your node and core allocations. You may need to do so for the following reasons:
