Job Submission and Monitoring
Resource Summary View (qsum)
To get started, users can query the overall status of resources on the cluster. The "qsum" script will list all queues and nodes, as well as how many are offline, down, free, or assigned to users. This is a script developed by our team, and may need to be updated if something goes wrong. Please contact us if you experience any problems.
Each queue groups a number of nodes together based on their hardware and software configurations. Nodes can be part of more than one queue, and there are other complex details that we are ignoring here for the purpose of keeping it simple.
Here is a very brief summary of what each of the queues is, and how to use them efficiently:
- a4000: This is a queue that has three 16-core CPU machines, each of which is furthermore equipped with three A4000 GPUs. That makes a total of 9 A4000 GPUs available to users. Neither the GPUs nor the processors are particularly powerful these days. The machines have 500GB of memory though, which makes for a good platform for experimenting with GPU capabilities.
- a6000: This is a queue that has only one 64-core CPU machines, and is equipped with four A6000 GPUs. The system can be upgraded to 8 A6000 GPUs if needed. This is a decent GPU machine that can take a solid workload these days. The machine has 750GB of memory, which makes for a good production platform.
- amd16: This is a queue with many of our older AMD-based 16-core machines, each of which has 30GB of memory. While individual machines are a bit outdated, they are all interconnected with Infiniband and can provide a solid production workload in multi-nodes jobs over MPI without blocking the more current (and thus expensive) systems.
- epyc1 and epyc2: These are 2 separate queues with slightly different performance characteristics. Each of the groups is interconnected with Infiniband to provide a platform for large and demanding software packages, such as LS-Dyna and StarCCM+. They have between 250GB and 500GB of memory. Because licenses for these software packages are very expensive, they should use these two queues for making optimum use of limited core licenses available to each package.
- xeon28: This is a set of intermediate machines with 28 cores and 64GB of memory. They can be used for a variety of purposes, including MPI jobs and single node application software.
- virtual: This is a set of nodes without MPI capabilities. They are virtual machines with 32GB each. They can be used for higher demand applications that would interfere with the login nodes, and therefore with other users of these login machines. A user would submit interactive jobs to individual virtual machines and avoid any significant load on login nodes.
$ qsum
=============== a4000 ==========================================================
Queue: "a4000" / nodes: 3 / down: 0 / offline: 0 / busy: 0 / available: 3
AVAILABLE (3): g001, g002, g003
=============== a6000 ==========================================================
Queue: "a6000" / nodes: 1 / down: 0 / offline: 0 / busy: 0 / available: 1
AVAILABLE (1): lambda01
=============== amd16 ==========================================================
Queue: "amd16" / nodes: 33 / down: 2 / offline: 0 / busy: 2 / available: 29
DOWN (2): n017, n030
ley (2): n001, n002
AVAILABLE (29): n003, n004, n005, n006, n007, n008, n009, n010, n011, n012
n013, n014, n015, n016, n018, n019, n020, n021, n022, n023
n024, n025, n026, n027, n028, n029, n031, n032, n039
=============== epyc1 ==========================================================
Queue: "epyc1" / nodes: 1 / down: 0 / offline: 0 / busy: 0 / available: 1
AVAILABLE (1): a027
=============== epyc2 ==========================================================
Queue: "epyc2" / nodes: 20 / down: 0 / offline: 0 / busy: 5 / available: 15
ley (2): a030, a031
msitek (3): a028, a029, a032
AVAILABLE (15): a033, a034, a035, a036, a037, a038, a039, a040, a041, a042
a043, a044, a045, a046, a047
=============== virtual ========================================================
Queue: "virtual" / nodes: 6 / down: 0 / offline: 0 / busy: 0 / available: 6
AVAILABLE (6): v001, v002, v003, v004, v005, v006
=============== xeon28 =========================================================
Queue: "xeon28" / nodes: 12 / down: 0 / offline: 0 / busy: 0 / available: 12
AVAILABLE (12): p001, p002, p003, p004, p005, p006, p007, p008, p009, p010
p011, p012
Queue Status and Monitoring Jobs
qstat
To find out out about the status of all running jobs on the cluster you can use the "qstat" command. Here is an example:
Nov 20 18:30 ley@login3:Plots$ qstat Job id Name User Time Use S Queue ---------------- ---------------- ---------------- -------- - ----- 3023.pbs STDIN msitek 4144:14* R epyc2 3029.pbs STDIN ley 76:46:53 R epyc2 3032.pbs STDIN msitek 2879:52* R epyc2 3033.pbs STDIN msitek 3687:29* R epyc2 3048.pbs foo.sh james.cook 0 Q amd16 3060.pbs of13.sh ley 310:47:* R epyc2 3061.pbs of13.sh ley 308:37:* R epyc2 3062.pbs of13.sh ley 308:02:* R epyc2 3063.pbs of13.sh ley 308:15:* R epyc2
The first column shows the job id, a unique identifier for all jobs ever submitted to the cluster. This job id is important when killing jobs, or for other actions you may need to take.
The next column shows the name of the job script. If the column shows STDIN, it means that this is an interactive job where a user can enter commands in a terminal window. This is particularly useful for model and software development task where the application has to be started and killed repeatedly.
The owner of the job is shown next. These are the user names of the various people using the cluster.
The last three columns indicate the current run time of the job, whether it is running (R) or waiting (Q) for execution. The last entry shows the queue in which the job is running.
qstat -an1
Adding a few options gives much more detail about each jobs.
Nov 20 13:09 ley@login3:Plots$ qstat -an1
pbs:
Req'd Req'd Elap
Job ID Username Queue Jobname SessID NDS TSK Memory Time S Time
3023.pbs msitek epyc2 STDIN 24360* 1 64 350gb 100:0 R 81:46 a028/0*64
3029.pbs ley epyc2 STDIN 21719* 2 128 100gb 200:0 R 72:31 a030/0*64+a031/0*64
3032.pbs msitek epyc2 STDIN 18102* 1 64 350gb 100:0 R 57:57 a029/0*64
3033.pbs msitek epyc2 STDIN 830486 1 64 350gb 100:0 R 57:53 a032/0*64
3048.pbs james.c* amd16 foo.sh -- 1 28 30gb 01:00 Q -- --
3060.pbs ley epyc2 STDIN 763101 1 64 350gb 48:00 R 06:42 a033/0*64
3061.pbs ley epyc2 STDIN 763947 1 64 350gb 48:00 R 06:40 a034/0*64
3062.pbs ley epyc2 STDIN 761473 1 64 350gb 48:00 R 06:39 a035/0*64
3063.pbs ley epyc2 STDIN 766205 1 64 350gb 48:00 R 06:40 a036/0*64
In this table, you can see how many nodes and cores are being used by each job. For example, job 3029 of the user "ley" shows that it is running on 2 nodes using a total of 128 cores. In addition to the elapsed time, the table also show the reserved time for this job. This allow you to estimate when a job will be definitely finalized (or killed by the system if still running).
The last column (without a header) is written because the option "-n1" was used. This useful to learn about which nodes are used by each job.
qstat -q
To learn more about the "qstat" command, you can use the command "man qstat", which will print a lot of detailed information about the capabilities of this command.
Job Submission Basics
This chapter is based on the TORQUE syntax for submitting jobs on the cluster. An updated version will be written to explain the syntax of the OpenPBS system, which works very similarly.
Sample LS-Dyna job submission script looks like this:
#!/bin/bash # #PBS -q extra #PBS -A ls-dyna #PBS -l nodes=2:ppn=64 #PBS -l walltime=100:: #PBS -j oe #PBS -N male_female #PBS -e log.error #PBS -o log.output #PBS -W x=NACCESSPOLICY:SINGLEJOB #PBS -m bae module load ls-dyna/MPP/SP/AVX2/12.2.1 cd $PBS_O_WORKDIR mpirun -machinefile $PBS_NODEFILE ls-dyna i=main.k memory1=300m memory2=100m module load dynamore/evaluation DM.plotcprs.lnx -merge
For an interactive session that makes it easier to troubleshoot your jobs during development, you can allocate machines for your job using the following syntax:
qsub -I -q extra -l nodes=2:ppn=64,walltime=24:00:00
LS-Dyna on the ARROW Cluster
Currently Available LS-Dyna Versions
The following is a list of LS-Dyna versions available on ARROW after the latest reconfiguration of the system. Versions below 12.0.0 are no longer available because they are not compatible with modern operating systems and cannot be made to work correctly.
All versions are loaded using the "module load" command. Versions can be listed with the "module avail ls-dyna" command. To load opne of the modules, use the following syntax:
module load ls-dyna/14.2.0/mpi-d8-ifort190-avx512
The version string is composed of multiple elements to indicate variants in compilers and compiler options. Use the following guideline to choose an appropriate version to load:
- "1" or "mpi" indicates whether this is a single node version of LS-Dyna or whether this is a multi-node MPI version. All MPI versions use the IntelMPI 2022 libraries which have been tested thoroughly on ARROW. MPI versions will use the Infiniband Network of ARROW for high-speed and low-latency inter-process communication using RDMA (remote direct memory access).
- All LS-Dyna versions are available in either floating point or double precision variants. Floating point variants use 4 bytes to represent a value, and double precision variants use 8 bytes. There are pros and cons for choosing one over the other variant. With regards to computational efficiency, both perform nearly the same because all machines are equipped with 64-bit CPUs.
- "f4" floating point versions
- Pros: These require significantly less memory to run. Results occupy less disk space, and can be transferred significantly faster into and out of ARROW.
- Cons: The numerical resolution is limited to 7 significant digits, which is often undesirable when dealing with mathematical operations on small and large numbers at the same time.
- "r8" double precision versions
- Pros: The numerical resolution is about twice the number of significant digits compare to "f4", which helps when when dealing with mathematical operations on small and large numbers at the same time.
- Cons: These require more memory to run. Results occupy more disk space, and it takes longer to transfer data into and out of ARROW.
- There are two more identifiers to choose from when it comes to the variants of the executables: the specific compiler used to create the executable and the specific processor instruction set required for running the executable.
- For modern versions of LS-Dyna, two compilers have been used by the developers to create LS-Dyna executables: the Intel Fortran Compiler and the AOCC (AMD Optimizing C/C++ and Fortran) compiler. Both variants of the software are supported on ARROW. This gives users the opportunity to choose an alternate variant of the same LS-Dyna version when running into bugs or crashes.
- The variants based on the various instruction set extensions (SSE2, AVX2, AVX512, and so on) gives users even more options when choosing an alternate LS-Dyna variant of the same version when running into bugs or crashes. These instruction sets are mostly related to performance gains on specific processors. We have not performed thorough performance tests and cannot recommend specific versions right now.
$ module avail ls-dyna ------------------------------------- /shared/apps/modulefiles ------------------------------------- ls-dyna/12.1.0/1-d8-aocc310 ls-dyna/14.1.0/mpi-d8-aocc400-avx2 ls-dyna/12.1.0/1-d8-ifort160 ls-dyna/14.1.0/mpi-d8-ifort190-avx2 ls-dyna/12.1.0/1-f4-aocc310 ls-dyna/14.1.0/mpi-d8-ifort190-avx512 ls-dyna/12.1.0/1-f4-ifort160 ls-dyna/14.1.0/mpi-d8-ifort190-sse2 ls-dyna/12.1.0/mpi-d8-aocc310-avx2 ls-dyna/14.1.0/mpi-f4-aocc400-avx2 ls-dyna/12.1.0/mpi-d8-ifort160-avx2 ls-dyna/14.1.0/mpi-f4-ifort190-avx2 ls-dyna/12.1.0/mpi-d8-ifort160-sse2 ls-dyna/14.1.0/mpi-f4-ifort190-avx512 ls-dyna/12.1.0/mpi-f4-aocc310-avx2 ls-dyna/14.1.0/mpi-f4-ifort190-sse2 ls-dyna/12.1.0/mpi-f4-ifort160-avx2 ls-dyna/14.2.0/1-d8-aocc400-avx2 ls-dyna/12.1.0/mpi-f4-ifort160-sse2 ls-dyna/14.2.0/1-d8-ifort190-sse2 ls-dyna/12.2.0/1-d8-aocc400 ls-dyna/14.2.0/1-f4-aocc400-avx2 ls-dyna/12.2.0/1-d8-ifort160 ls-dyna/14.2.0/1-f4-ifort190-sse2 ls-dyna/12.2.0/1-f4-aocc400 ls-dyna/14.2.0/mpi-d8-aocc400-avx2 ls-dyna/12.2.0/1-f4-ifort160 ls-dyna/14.2.0/mpi-d8-ifort190-avx2 ls-dyna/12.2.0/mpi-d8-aocc400-avx2 ls-dyna/14.2.0/mpi-d8-ifort190-avx512 ls-dyna/12.2.0/mpi-d8-ifort160-avx2 ls-dyna/14.2.0/mpi-d8-ifort190-sse2 ls-dyna/12.2.0/mpi-d8-ifort160-sse2 ls-dyna/14.2.0/mpi-f4-aocc400-avx2 ls-dyna/12.2.0/mpi-f4-aocc400-avx2 ls-dyna/14.2.0/mpi-f4-ifort190-avx2 ls-dyna/12.2.0/mpi-f4-ifort160-avx2 ls-dyna/14.2.0/mpi-f4-ifort190-avx512 ls-dyna/12.2.0/mpi-f4-ifort160-sse2 ls-dyna/14.2.0/mpi-f4-ifort190-sse2 ls-dyna/12.2.1/1-d8-aocc400-avx2 ls-dyna/15.0.2/1-d8-aocc400-avx2 ls-dyna/12.2.1/1-d8-ifort160-sse2 ls-dyna/15.0.2/1-d8-ifort190-sse2 ls-dyna/12.2.1/1-f4-aocc400-avx2 ls-dyna/15.0.2/1-f4-aocc400-avx2 ls-dyna/12.2.1/1-f4-ifort160-sse2 ls-dyna/15.0.2/1-f4-ifort190-sse2 ls-dyna/12.2.1/mpi-d8-aocc400-avx2 ls-dyna/15.0.2/mpi-d8-aocc400-avx2 ls-dyna/12.2.1/mpi-d8-ifort160-avx2 ls-dyna/15.0.2/mpi-d8-ifort190-avx2 ls-dyna/12.2.1/mpi-d8-ifort160-sse2 ls-dyna/15.0.2/mpi-d8-ifort190-avx512 ls-dyna/12.2.1/mpi-f4-aocc400-avx2 ls-dyna/15.0.2/mpi-d8-ifort190-sse2 ls-dyna/12.2.1/mpi-f4-ifort160-avx2 ls-dyna/15.0.2/mpi-f4-aocc400-avx2 ls-dyna/12.2.1/mpi-f4-ifort160-sse2 ls-dyna/15.0.2/mpi-f4-ifort190-avx2 ls-dyna/12.2.2/1-d8-aocc400-avx2 ls-dyna/15.0.2/mpi-f4-ifort190-avx512 ls-dyna/12.2.2/1-d8-ifort160-sse2 ls-dyna/15.0.2/mpi-f4-ifort190-sse2 ls-dyna/12.2.2/1-f4-aocc400-avx2 ls-dyna/16.0.0/1-d8-aocc420-avx2 ls-dyna/12.2.2/1-f4-ifort160-sse2 ls-dyna/16.0.0/1-d8-aocc420-avx512 ls-dyna/12.2.2/mpi-d8-aocc400-avx2 ls-dyna/16.0.0/1-d8-ifort190-sse2 ls-dyna/12.2.2/mpi-d8-ifort160-avx2 ls-dyna/16.0.0/1-f4-aocc420-avx2 ls-dyna/12.2.2/mpi-d8-ifort160-sse2 ls-dyna/16.0.0/1-f4-aocc420-avx512 ls-dyna/12.2.2/mpi-f4-aocc400-avx2 ls-dyna/16.0.0/1-f4-ifort190-sse2 ls-dyna/12.2.2/mpi-f4-ifort160-avx2 ls-dyna/16.0.0/mpi-d8-aocc420-avx2 ls-dyna/12.2.2/mpi-f4-ifort160-sse2 ls-dyna/16.0.0/mpi-d8-aocc420-avx512 ls-dyna/13.0.0/1-d8-ifort190 ls-dyna/16.0.0/mpi-d8-ifort190-avx2 ls-dyna/13.0.0/1-f4-ifort190 ls-dyna/16.0.0/mpi-d8-ifort190-avx512 ls-dyna/13.0.0/mpi-d8-ifort190-avx2 ls-dyna/16.0.0/mpi-d8-ifort190-sse2 ls-dyna/13.0.0/mpi-d8-ifort190-sse2 ls-dyna/16.0.0/mpi-f4-aocc420-avx2 ls-dyna/13.0.0/mpi-f4-ifort190-avx2 ls-dyna/16.0.0/mpi-f4-aocc420-avx512 ls-dyna/13.0.0/mpi-f4-ifort190-sse2 ls-dyna/16.0.0/mpi-f4-ifort190-avx2 ls-dyna/13.1.0/mpi-d8-aocc310-avx2 ls-dyna/16.0.0/mpi-f4-ifort190-avx512 ls-dyna/13.1.0/mpi-d8-ifort190-avx2 ls-dyna/16.0.0/mpi-f4-ifort190-sse2 ls-dyna/13.1.0/mpi-d8-ifort190-sse2 ls-dyna/16.1.0/mpi-d8-aocc420-avx2 ls-dyna/13.1.0/mpi-f4-aocc310-avx2 ls-dyna/16.1.0/mpi-d8-aocc420-avx512 ls-dyna/13.1.0/mpi-f4-ifort190-avx2 ls-dyna/16.1.0/mpi-d8-ifort190-avx2 ls-dyna/13.1.0/mpi-f4-ifort190-sse2 ls-dyna/16.1.0/mpi-d8-ifort190-avx512 ls-dyna/13.1.1/mpi-d8-ifort190-avx2 ls-dyna/16.1.0/mpi-d8-ifort190-sse2 ls-dyna/13.1.1/mpi-d8-ifort190-sse2 ls-dyna/16.1.0/mpi-f4-aocc420-avx2 ls-dyna/13.1.1/mpi-f4-ifort190-avx2 ls-dyna/16.1.0/mpi-f4-aocc420-avx512 ls-dyna/13.1.1/mpi-f4-ifort190-sse2 ls-dyna/16.1.0/mpi-f4-ifort190-avx2 ls-dyna/14.0.0/1-d8-aocc310 ls-dyna/16.1.0/mpi-f4-ifort190-avx512 ls-dyna/14.0.0/1-d8-ifort190 ls-dyna/16.1.0/mpi-f4-ifort190-sse2 ls-dyna/14.0.0/1-f4-aocc310 ls-dyna/16.1.1/mpi-d8-aocc420-avx2 ls-dyna/14.0.0/1-f4-ifort190 ls-dyna/16.1.1/mpi-d8-aocc420-avx512 ls-dyna/14.0.0/mpi-d8-aocc310-avx2 ls-dyna/16.1.1/mpi-d8-ifort190-avx2 ls-dyna/14.0.0/mpi-d8-ifort190-avx2 ls-dyna/16.1.1/mpi-d8-ifort190-avx512 ls-dyna/14.0.0/mpi-d8-ifort190-sse2 ls-dyna/16.1.1/mpi-d8-ifort190-sse2 ls-dyna/14.0.0/mpi-f4-ifort190-avx2 ls-dyna/16.1.1/mpi-f4-aocc420-avx2 ls-dyna/14.0.0/mpi-f4-ifort190-sse2 ls-dyna/16.1.1/mpi-f4-aocc420-avx512 ls-dyna/14.1.0/1-d8-aocc400-avx2 ls-dyna/16.1.1/mpi-f4-ifort190-avx2 ls-dyna/14.1.0/1-d8-ifort190-sse2 ls-dyna/16.1.1/mpi-f4-ifort190-avx512 ls-dyna/14.1.0/1-f4-aocc400-avx2 ls-dyna/16.1.1/mpi-f4-ifort190-sse2 ls-dyna/14.1.0/1-f4-ifort190-sse2
