ARROW Cluster under construction
From TRACC Wiki
Revision as of 20:56, March 11, 2025 by Amiot (talk | contribs) (PBS Computing Queues)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
There are currently several queues that are available, some with restrictions about who can use them as described below. Also be aware that all nodes in some queues have the same characteristics (RAM, etc) while some queues have nodes with different characteristics. Thus jobs using those queues must specify the node names that are to be used.
The queues "Torque Computing Queues" are scheduled by the Torque scheduler and is available by default.
The queues "PBS Computing Queues" are available after the environmental specifying the PBS Scheduler is initiated
 module load pbs/pbs
ARROW Computing Queues
  • batch
  • nhtsa
  • virtual
  • arrow
  • gpu
  • extra
  • lambda
  • epyc3
  • workq
  • xeon28
  • virtual
  • a4000
    • GPU
  • a6000
    • GPU
Return To Main Page
Return to Setting Up Your Environment
Return to Scheduling a Computing Node(s)
