GPU Nodes under construction
From TRACC Wiki
Revision as of 22:57, February 3, 2025 by Amiot (talk | contribs) (ARROW GPU Nodes)
ARROW GPU Nodes
Arrow currently has two sets of GPU nodes.The first set consists of three NVIDIA RTX A4000 GPUs. The second set consists
of four NVIDIA RTX A6000 GPUs. These GPU nodes must be requeted using the PBS scheduler.
First you must use your client computer running a terminal program to log onto one of the logon nodes. In this case I used logon1.arrow.tracc.anl.gov. Then I used login1 to ssh to a4000.
Following is a sample program that shows how to log onto the a4000 specifying two of the 3 GPUs, 16 of the CPUs, 150G of memory, and a maximum running time of three hours. The request is queued using the qsub command with the PBS scheduler. Any of a4000 components not requested are then available for another user (or another instance of this user) to request and use.
 ssh [email protected]
 [email protected]'s password:PaSsWD
