Under construction to ARROW Cluster
Introduction To ARROW
TRACC has combined the original hardware from the Phoenix and Zephyr clusters into the ARROW cluster. This consolidation allows efficient administration of TRACC cluster services with limited staff. To avoid the problems of load balancing, the different types of hardware nodes on the ARROW cluster are partitioned and available in queues. When new hardware is installed to expand cluster resources, it will be made available via a new queue. The documentation at Using the Cluster describes procedures for using ARROW.
ARROW is arranged such that there is a single set of 4 login nodes, a singe file system, and single user home directory that serves all of the nodes in all of the queues.
ARROW Queues
There are currently several queues that are available, some with restrictions about who can use them as described below. Also be aware that all nodes in some queues have the same characteristics (RAM, etc) while some queues have nodes with different characteristics. Thus jobs using those queues must specify the node names that are to be used. Fred
- batch queue (default queue)
- 95 nodes numbered n005 through n099
- 2 x AMD Opteron 6276
- 16 floating point cores per node
- 32GB of RAM per node
- available for general use
- batch128 queue
- 2 nodes numbered n001 and n002
- Same design as batch queue
- 128GB of RAM per node
- batch64 queue
- 2 nodes numbered n003 and n004
- 64GB of RAM per node
- nhtsa queue
- 12 nodes numbered p001 through p012
- 2 x Intel Xeon E5-2690 v4
- 28 floating point cores per node
- only available to the NHTSA project
- arrow queue
- 15 nodes numbered a001 through a015
- 1 x Intel EPYC 7702P
- 64 floating point cores per node
- 256GB of RAM per node, 512GB on nodes a001 through a003
- extra queue
- 12 nodes numbered a0016 through a027
- 1 x Intel EPYC 7713P
- 256GB of RAM per node, 512GB on nodes a018 through a022
- note: this queue will likely be merged into the arrow queue in the future
- virtual queue
- 5 nodes numbered v001 through v005
- Mostly for internal testing and validation, can be used as 2 core machines with 32GB memory
- Minimal virtual hardware, not capable of running engineering applications
