Python
From TRACC Wiki
Revision as of 21:14, July 6, 2021 by Amiot (talk | contribs) (Arrow)
Arrow
The default version of Python on Arrow is 2.7.5. and does not require a module to be loaded. You can start the interactive version by entering the command
python2
To run the batch version, start your script with
#!/usr/bin/env python2
The default version of python3 (3.6.8) along with sympy, numpy, and ipython are also installed, but you must load the python libraries. You can use the interactive version by entering the commands
module load python/3.8.2
python3
You can use the batch version by starting your script with
module load python/3.3.2
You can see general information about modules at Setting Up Your Environment#Accessing application software with modules
