ARROW Cluster
Introduction To ARROW
TRACC has now combined the hardware from the Phoenix and Zephyr clusters into the ARROW cluster. This consolidation allows efficient administration of TRACC cluster services with limited staff. To avoid the problems of load balancing, the different types of hardware nodes on the ARROW cluster are partitioned and available in queues. When new hardware is installed to expand cluster resources, it will be made available via a new queue. The documentation at Using the Clusters describes procedures for using ARROW.
ARROW is arranged such that there is a single set of login nodes, a singe file system, and single user home directory that serves all of the nodes in all of the queues.
ARROW Queues
There are currently several queues that are available, some with restrictions about who can use them as described below.
- batch (default queue, with 90 nodes, each node with 16 floating point cores available for general use)
- 92 nodes each with 32 GB of RAM
- batch128
- 2 nodes (n001 and n002) each with 128GB
- Available for general usage
- batch65
- 2 nodes (n003 and n004) each with 64GB
- nhtsa (with 12 nodes, each with 28 cores and 64 GB of RAM, only available to the NHTSA project)
- arrow (one new EPYC server with 64 cores, for use for testing by TRACC staff or special permission by the TRACC Director)
- virtual (This queue is only available for testing and is considered under construction. Please do not use for now.)
- test (This queue is only available for testing, and is only available with permission by the TRACC Director. The nodes as currently configure are
not very powerful but have large amounts of RAM.)
