Python
Zephyr
The default version of Python on the Zephyr cluster is 2.6.6. Python 2.7 and wxPython2.7 are also installed and do not require a module to be loaded.
Python 3.3.2 along with sympy, numpy, and ipython are also installed. To use this version of Python, please load the python/3.3.2 module
$ module load python/3.3.2 $ python
or
$ ipython
Phoenix
The default version of Python on the Phoenix cluster is 2.3.4, the version which comes with Red Hat 4.5. We also have versions 2.6 and 3.0 installed in /soft/python/bin. To use them, you'll need to either fully specify the path to the version you want to use, or load the appropriate module. The modules alias python to the module version and set LD_LIBRARY_PATH, which helps to eliminate some errors that you may otherwise encounter when you use Python modules.
$ /soft/python/bin/python2.6 $ /soft/python/bin/python3.0
or
module load python/2.6 module load python/3.0
For example,
$ module load python/2.6 $ python
Python modules
We add Python modules (i.e., libraries) as users request them. The non-default site packages are in /soft/python/lib/python<version>/site-packages.
If you encounter any problems with a Python library module, try loading the Python environment module (as above).
