STARCCM+ Fusion
First, you need to get the correct path to STAR-CCM+ in your $PATH environmental variable. On Fusion, this is managed by SoftEnv. To add the current version to your path, add the key +starccm+-6.02.007 to your .soft file:
cat >> .soft <<EOF +starccm+-6.02.007 EOF resoft
Check your environment by issuing the command:
which starccm+
This should return:
/soft/starccm+/6.02.007/starccm+6.02.007/star/bin/starccm+
Here is a sample PBS script for submitting STAR-CCM+ jobs. In addition to the above STAR-CD sample, this script runs commands that time the run. Note: This script requires you to change the name of the .sim file. This one looks for one named "star.sim "
#!/bin/sh #PBS -lnodes=4:ppn=4,walltime=48:00:00 #PBS -N starcccmp_q #PBS -j oe #PBS -V cd $PBS_O_WORKDIR # # get the hosts in a format the star utility requires # NHOSTS=`cat $PBS_NODEFILE | wc -l` # echo '#######################################' echo " " echo '++++ began:' `date` echo '++++ # of hosts: ' $NHOSTS which starccm+ echo " " echo '#######################################' echo " " TBEGIN=`echo "print time();" | ssh eddyeth perl` starccm+ -batch -np $NHOSTS -machinefile $PBS_NODEFILE -rsh ssh star.sim > starccmp.log 2>&1 TEND=`echo "print time();" | ssh eddyeth perl` echo " " echo '++++ ended:' `date`
