Grafana + InfluxDB
Introduction
In order to monitor the HELIOS system, for example, the threshold, the tigger rate, the buffer size, etc. We monitor and save those data into a database managed by InfluxDB. The database is further read by Grafana for display.
For more information on InfluxDB and Grafana, see:
Present setting
The data (e.g. trigger Rate, threshold, Buffer ) must be taking in digios1, the DAQ.
Since the DAQ is running on a 32-bit system. the influxDB is unstable.
The database was installed in heliosDB.onenet.
Thus, the data will be push to heliosDB.
Grafana was also installed in heliosDB.
Setup InfluxDB
For 64bit-linux, the setup is straight forward.
For example, in Ubuntu-18.x, simply type
sudo apt-get install influxdb
The influxdb contains 2 main programs,
- influx, for interactive database operations
- influxd, a daemon run in background, for receiving query from port 8086
To run the influxd
sudo service influxdb start
Present setting
The bash script in ~/digios/daq/edm/script/helios_database
