Flattened Makefile 1
From HELIOS Digital DAQ
Using a pile of copy/paste, let's try to build a flat makefile from the many levels of other files including other files. This isn't just a simple copy/paste operation, because we also have to expand all the variable references for paths, but some variables are re-used. In doing this we have to realize that Make acts like a two-pass assembler, first building the symbol table (so forward reference is technically legal), then doing all the expansion of the symbols and handling the rules that have been invoked by the user. When invoking make you can supply a list of rules (actions) at the command line and make will dig through the makefiles to find the matching segments of actions corresponding to each rule. Nice idea but hard to work with if that means significant amounts of the code are never used because all the user ever does is say 'make' with no arguments.
#Makefile at top of application tree
TOP = .
#CONFIG
# CONFIG_APP
#RELEASE Location of external products
# Run "gnumake clean uninstall install" in the application
# top directory each time this file is changed.
# NOTE: The build does not check dependancies on files
# external to this application. Thus you should run
# "gnumake clean uninstall install" in the top directory
# each time EPICS_BASE, SNCSEQ, or any other external
# module defined in the RELEASE file is rebuilt.
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
GRETVME=./../gretVME
DATASERVER=./../gretClust
#If using the sequencer, point SNCSEQ at its top directory:
SNCSEQ=/global/develbuild/supTop/31410/sncseq-2.0.12
ASYN=/global/develbuild/synApps/asyn/asyn4-17
# EPICS_BASE usually appears last so other apps can override stuff:
#EPICS_BASE=/global/develbuild/base/R3.14.10
EPICS_BASE=/global/develbuild/base/base-3.14.12.1
#Capfast users may need the following definitions
#CAPFAST_TEMPLATES=
#SCH2EDIF_PATH=
-include ./configure/RELEASE.$(EPICS_HOST_ARCH)                          ##jta: forward definition
-include ./configure/RELEASE.Common.$(T_A)                               ##jta: forward definition
-include ./configure/RELEASE.$(EPICS_HOST_ARCH).$(T_A)                   ##jta: forward definition
CONFIG=/global/develbuild/base/base-3.14.12.1/configure
# assume T_A is the host arch if not specified
#  Common build definitions
The following snippet likely never gets used by us...
ifneq ($(wildcard ./configure/CONFIG_BASE_VERSION),)
EPICS_BASE = $(INSTALL_LOCATION)
CONFIG = ./configure
BASE_TOP=YES
else
CONFIG ?= $(EPICS_BASE)/configure
endif
# Provide a default if the user hasn't set EPICS_HOST_ARCH
ifeq ($(origin EPICS_HOST_ARCH), undefined)
# NB: Must use a simply expanded variable here for performance:
EPICS_HOST_ARCH := $(shell $(CONFIG)/../startup/EpicsHostArch.pl)
endif
-include $(CONFIG)/os/CONFIG_COMPAT
-include $(CONFIG)/RELEASE
-include $(CONFIG)/RELEASE.$(EPICS_HOST_ARCH)
-include $(CONFIG)/RELEASE.$(EPICS_HOST_ARCH).Common
ifdef T_A
-include $(CONFIG)/RELEASE.Common.$(T_A)
-include $(CONFIG)/RELEASE.$(EPICS_HOST_ARCH).$(T_A)
endif
But at this point we get back to yet more includes...
include $(CONFIG)/CONFIG_COMMON
include $(CONFIG)/CONFIG_FILE_TYPE
#  Base-specific build options
include $(CONFIG)/CONFIG_BASE
#  Site-specific build options
include $(CONFIG)/CONFIG_SITE
#  Version numbering
include $(CONFIG)/CONFIG_BASE_VERSION
#  Host architecture specific definitions
include $(CONFIG)/os/CONFIG.$(EPICS_HOST_ARCH).Common
-include $(CONFIG)/os/CONFIG_SITE.$(EPICS_HOST_ARCH).Common
ifdef T_A
#  Cross compile specific definitions
ifneq ($(EPICS_HOST_ARCH),$(T_A))
include $(CONFIG)/CONFIG.CrossCommon
endif
#  Target architecture specific definitions
-include $(CONFIG)/os/CONFIG.Common.$(T_A)
#  Host-Target architecture specific definitions
-include $(CONFIG)/os/CONFIG.$(EPICS_HOST_ARCH).$(T_A)
#  RELEASE file specific definitions
ifneq ($(CONFIG),./configure)
-include $(CONFIG)/CONFIG_APP_INCLUDE
endif
#  Site specific target and host-target definitions
-include $(CONFIG)/os/CONFIG_SITE.Common.$(T_A)
-include $(CONFIG)/os/CONFIG_SITE.$(EPICS_HOST_ARCH).$(T_A)
endif
# Include <top>/cfg/CONFIG* definitions from tops defined in RELEASE* files
RELEASE_TOPS := $(shell $(CONVERTRELEASE) -T . releaseTops)
RELEASE_CFG_CONFIGS = $(foreach top, $(RELEASE_TOPS), $(wildcard $(.)/cfg/CONFIG*))
ifneq ($(RELEASE_CFG_CONFIGS),)
include $(RELEASE_CFG_CONFIGS)
endif
endif
# Include $(INSTALL_CFG)/CONFIG* definitions
ifndef T_A
TOP_CFG_CONFIGS = $(wildcard $(INSTALL_CFG)/CONFIG*)
ifneq ($(TOP_CFG_CONFIGS),)
include $(TOP_CFG_CONFIGS)
endif
endif
#  User specific definitions
-include $(HOME)/configure/CONFIG_USER
-include $(HOME)/configure/CONFIG_USER.$(EPICS_HOST_ARCH)
ifdef T_A
-include $(HOME)/configure/CONFIG_USER.Common.$(T_A)
-include $(HOME)/configure/CONFIG_USER.$(EPICS_HOST_ARCH).$(T_A)
endif
#  All options
#   may be overridden here.
# EXAMPLES
#  Build client objects statically ?  must be either YES or NO
#STATIC_BUILD=NO
#  Host build optimization,   must be either YES or NO
#HOST_OPT=YES
#  Cross build optimization,  must be either YES or NO
#CROSS_OPT=YES
#  Generate Verbose Compiler Warnings for host build,  must be either YES or NO
#HOST_WARN=YES
#  Generate Verbose Compiler Warnings for cross compile builds,  must be either YES or NO
#CROSS_WARN=YES
#etc.
#CROSS_COMPILER_TARGET_ARCHS=vxWorks-68040
INSTALL_LOCATION = .
ifdef INSTALL_LOCATION_APP
INSTALL_LOCATION = $(INSTALL_LOCATION_APP)
endif
ifdef T_A
-include ./configure/O.$(T_A)/CONFIG_APP_INCLUDE
endif
# dbst based database optimization (default: NO)
DB_OPT = NO
# Add any changes to make definitions here
#CROSS_COMPILER_TARGET_ARCHS = vxWorks-68040
# Use this when your IOC and the host use different paths
# to access the application. Typically this will be
# used with the Microsoft FTP server or with NFS mounts. Use
# is indicated by failure of the cdCommands script on
# vxWorks. You must rebuild in the iocBoot directory
# before this takes effect.
#IOCS_APPL_TOP = <the top of the application as seen by the IOC>
DIRS := $(DIRS) $(filter-out $(DIRS), configure)
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard *App))
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard *app))
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard iocBoot))
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard iocboot))
include ./configure/RULES_TOP
