MakeFile Archaeology
Digging up the make file and all that it refers to
We start with the makefile itself, found at /global/devel/gretTop/9-22/dgsDrivers. The makefile presumes that it is being run from the top of the development tree, setting internal variable TOP to ".".
- The makefile then includes the contents of the file /global/devel/gretTop/9-22/dgsDrivers/configure/CONFIG.
- This file includes the file /global/devel/gretTop/9-22/dgsDrivers/configure/CONFIG_APP but all other lines are commented out.
- File /global/devel/gretTop/9-22/dgsDrivers/configure/CONFIG_APP itself then pulls in /global/devel/gretTop/9-22/dgsDrivers/configure/RELEASE but the other files are not included because the "-include" directive means "do not include". Guess that's a backwards way to comment out the line.
Thus at this point in the make what has realled happened is that we've pulled in /global/devel/gretTop/9-22/dgsDrivers/configure/RELEASE but nothing else has occurred.
File /global/devel/gretTop/9-22/dgsDrivers/configure/RELEASE
- defines a variable TEMPLATE_TOP that is not used later within this file, and is dependent upon the definition of the variable EPICS_BASE that occurs later in this same file.
- defines a variable GRETVME that parses out to /global/devel/gretTop/9-22/gretVME.
- defines a variable DATASERVER that parses out to /global/devel/gretTop/9-22/gretClust.
- defines a variable SNCSEQ to /global/develbuild/supTop/31410/sncseq-2.0.12.
- Obscure comment about needing SNCSEQ defined "if using the sequencer", but at this point we don't know what a "sequencer" is.
- defines a variable ASYN to /global/develbuild/synApps/asyn4-17.
- No comment available but we guess that this is intended for later use to bring in the ASYN driver C++ stuff later.
- defines the variable EPICS_BASE to the value /global/develbuild/base/base-3.14.12.1.
- This is probably something that will be dependent upon which processor is in use as different processors may have different versions of EPICS.
- and then a couple more commented-out lines.
So at this point we have Variable TOP is set to /global/devel/gretTop/9-22/dgsDrivers. Variable GRETVME is set to /global/devel/gretTop/9-22/gretVME. Variable DATASERVER is set to /global/devel/gretTop/9-22/gretClust. Variable SNCSEQ is set to /global/develbuild/supTop/31410/sncseq-2.0.12. Variable ASYN is set to /global/develbuild/synApps/asyn4-17. Variable EPICS_BASE is set to /global/develbuild/base/base-3.14.12.1. Variable TEMPLATE_TOP may be set to /global/develbuild/base/base-3.14.12.1/templates/makeBaseApp/top.
