VME99 test stand IOC
VME99
The concept of "VME99" is to integrate the firmware development test stand more fully as part of the experiments. The goal is to provide a system designed specifically for development of IOC software unique from any experimental system so that development work can proceed freely without risk to any running setup.
Hardware To Do
- Cable to setup a terminal without a terminal server. JTA will do this by end of 5/4/18.
Software To Do (most is in ppt file attached)
- Implementation of system config file into the Python scripts for building a specific system. E.g., vme99, xdigitizers. Need names of lists and locations, anything else? Mike will look at getting a system config file going [report on it next week]. - Modify of the Makefile to only compile what is needed. Mike and JTA both looking at the Makefile. - Best path forward? The correct path or simple path [start with correct path]? Argument for the simple path is to get Gammaware working on linux?
