Sorting Data
Overiew
This is a guide to help sort large amounts of DigiOS data using the GEBMerge and GEBSort_nogeb procedures.
- GEBMerge is used to time-stamp sort all digitizer / ioc data files of type gtd
- GEBSort_nogeb is used to create events in the data and process the data if desired. Presently, it passes all of the header information to a ROOT TTree file. Trace data can also be passed if so chosen.
Both files have *.chat files that define the parameters of the sort. For example, the number of pieces of data to sort, or the coincidence window defining an event.
Example
- Go to /music/helios2/DigiOS/working
- Check that data file(s) in data directory
ls -ltr ../data -r--r--r-- 1 crhoffman helios 21250344 Oct 6 11:12 data_run_004.gtd_000_0103 -r--r--r-- 1 crhoffman helios 1801997700 Oct 6 11:15 data_run_004.gtd_000_0102
- Merge run 004
./gebmerge 004 RUN 004: GEBMerge started at Tue Oct 11 16:07:03 CDT 2016 RUN 004: GEBMerge DONE at Tue Oct 11 16:07:40 CDT 2016
If you get an error about no GEBMerge, go to GEBSort directory and type
make GEBMerge
- Next run GEBSort_nogeb to generate root file
./gebsort 004 GEBSort started sorting run 004 at Tue Oct 11 16:11:16 CDT 2016
from GEBSort.cxx on Oct 7 2016 15:45:02
...tons of other crap... done saving rootfile "/music/helios2/DigiOS/root_data/run004.root read 611072 events; Pars.beta=0.0000; time since last update 0 minutes CommandFileName="GEBSort.command" sorted timestamp range 594573853956-->7526345374265: 6931771520309 that is 69317.7 seconds or 19h15m17s ^^^^^ any timestamp jumps will upset this accounting hit statistics per type 14 GEB_TYPE_DGS 1957499 ; 28.24 Hz read a total of 1957499 ; header/payloads Duration of sort in real time 45.02 s Sort time ratio (real t / dTS) SMALLER IS BETTER: 0.00065 boniva sancta! ...GEBSort (unexpectedly) did not crash! ** GEBSort is done at Tue Oct 11 16:12:03 2016 GEBSort DONE at Tue Oct 11 16:12:03 CDT 2016
Locations of Working Sort Codes
As of now, I (CRH) have been using a set of codes on malaguena.onenet. I login using my own username (not helios@phy), and I reccommend this for everyone. If we need to change some permissions, or get people on the same group we can do it. But it will be confusing to have everyone as helios.
The current working directory for the GEBMerge and GEBSort_nogeb codes is /music/helios2/DigiOS/GEBSort
Other directories in music/helios2/DigiOS include
codes data GEBSort merged_data root_data working
As you will see below, running GEBMerge and GEBSort_nogeb can be involved, hence, in the working directory, there are a few *.sh scripts to help run them, e.g., to merge run 004 in the data directory, in working type
gebmerge.sh 004
Please note that the file locations are hardcoded at this point so change them if you intend to play around with things!
Running GEBMerge
It is run in the following way (NOTE: A map.dat file is required in execution directory even if it is empty??) :
GEBMerge merge_chat_file.chat merged_output_file.gtd data_file(s).gtd
The merge_chat_file.chat includes a number of parameters defining the sort. My (CHR) current working on is in /music/helios2/DigiOS/working
Also, a more simple way to run the merge is to use the gebmerge.sh script as
gebmerge.sh 004
to sort the data run 004 in the data directory
Runing GEBSort_nogeb
Please note, if you modify GEBSort, you want to make GEBSort_nogeb (NO Global Event Builder), otherwise it will fail because it is meant to get realtime data from Gretina (i think).
GEBSort_nogeb is run by
GEBSort_nogeb -input input_type [input_data_file.gtd] -rootfile output_root_file.root rootfile_option -chat chat_file.chat
- input_type -> disk : to indicate from file (not online)
- input_data_file.gtd : can be merged or single-IOC file (I believe)
- rootfile_option -> RECREATE or UPDATE : whether to create new or add to the root file specified
Other files required by GEBSort_nogeb (all to be placed in working directory)
- map.dat : gives ID’s and types of channels (can be an empty file, but must be there it seems)
GEBSort_nogeb OUTPUT
The present version of the code uses the bin_rcnp.* files to generate a ROOT TTree with the information from the header. There are still some issues with the full readout of the header, but all information for timestamps and energy is there now (extra stuff is for better P/Z corrections, etc.). The root TTree should be nearly identical to the parameters given in the typedef struct DGSEVENT' which is found in GTMerge.h
