System usage
Details Pertaining to the Usage of the System
Just going to write a bunch of stuff here for now and sort it into something more digestible later on...
Starting the EDM-based acquisition
The acquisition computer is located at digios1.onenet and we are using the logon name and password of dgs
ssh -X [email protected]
Note that on logon it will say dgs@helios1, this should be modified to match digios1.
The working directory of the acquisition gui is
/global/devel/systems/helios
and is based off of the mobacq directory.
To bring up the gui
heliosCommander
using _editable if you know what you are doing. Also, there is a link to the heliosCommander executable in the dgs home directory at the moment (NEED TO MAKE THIS EASY AND UNIVERSAL).
This will bring up the edm 1-12-3 (on helios1) window, as well as the RunControl gui. If it does not, see Known Issues below. This script will also set environment variables such as
export EDMOBJECTS=/global/devel/extensions/dgs1/src/edm/setup export EDMHELPFILES=/global/devel/extensions/dgs1/src/edm/helpFiles export EDMBASE=/global/devel/extensions/dgs1/src/edm export EDM=/global/devel/extensions/dgs1/src/edm/edmMain/O.linux-x86/edm export EDMPVOBJECTS=/global/devel/extensions/dgs1/src/edm/setup export EDMFILES=/global/devel/extensions/dgs1/src/edm/setup export EDMDATAFILES=$EDMDATAFILES:/global/devel/systems/helios/edm/screens export EDMSCRIPTS=/global/devel/systems/helios/edm/scripts
Note that the EDMSCRIPTS location is where most of the scripts called through the gui run from and EDMDATAFILES holds the various gui screen files.
On RunControl gui select TS/Setup->IOC#, where # is the IOC number, to make sure IOC# has booted up. This calls a script called terminals with option #+2. For example to start IOC1
terminals 3
On RunControl gui select TS/Setup->SoftIOC to boot SoftIOC. This calls a script called terminals with option 1.
terminals 1
SoftIOC will then boot, ending with epics> gretClustGT.sav: 929 of 929 PV's connected. The soft IOC calls a script (NEED INFO HERE).
On RunControl gui select TS/Setup->Digitizer Setup. This calls a script called dig_setup. This script holds a lot of the meat for setting up the digitizers and getting the system running. A list of the parameters and their meanings can be found at File:Dig reg map with vba.xls but be aware that this file is subject to change. The most up to date version can be found on the internal svn site (NEED LINK TO SVN HERE).
If all scripts are set properly should be able to start acquisition at this point.
Data Taking
To collect data you must start data collection from an ioc through the command (NEED MORE INFO HERE)
gtReceiver# <server> <filename> <maxfilesize> <GEBID>
0 1 2 3 4
e.g: gtReceiver4 ioc1 data_run_001.gtd 2000000000 14
GEBID=14 is DGS data
GEBID=15 is DGSTRIG data
GEBID=16 is DFMA data
<maxfilesize> specifies the max file size in bytes. If a file runs over the limit a new file will be openend with a new counter number at the end. A value of 2000000000 or less ensures the files are less than 2GB and can be read by all operating systems.
NOTE: use 'ctrl-c' to stop this receiver program (it will then clean and close properly)
where the # refers to the version number of the Receiver software. At present we are using #=4. The <server> location in found in /etc/hosts file, the <filename> is the .gtd extension, and <maxfilesize> is typically set to 2e9 to make sure files are smaller than 2GB each.
This software can be obtained at [gtReceiver svn location]. There is a checked out version of this located at ~/Receiver/ and the executable has been put in ~/bin_Linux_i386/.
A start script can be used to start the gtReceiver (SHOULD BE MADE INTO A BUTTON), such as this one taken from dgs1 on 6/22/15.
#!/bin/bash -l export TERM=vt100 echo " terminals" # Now spawn receiver windows for IOC1-11. xterm -T ioc1 -geometry 110x24+0+0 -sb -sl 1000 -e "gtReceiver4" "ioc1" "run_$1.gtd01" "2000000000" "14" & xterm -T ioc2 -geometry 110x24+0+370 -sb -sl 1000 -e "gtReceiver4" "ioc2" "run_$1.gtd02" "2000000000" "14" & xterm -T ioc3 -geometry 110x24+0+740 -sb -sl 1000 -e "gtReceiver4" "ioc3" "run_$1.gtd03" "2000000000" "14" & xterm -T ioc4 -geometry 110x24+400+0 -sb -sl 1000 -e "gtReceiver4" "ioc4" "run_$1.gtd04" "2000000000" "14" & xterm -T ioc5 -geometry 110x24+400+370 -sb -sl 1000 -e "gtReceiver4" "ioc5" "run_$1.gtd05" "2000000000" "14" & caput Online_CS_SaveData Save caput GLBL:DIG:disc_width 15 # this is to just for safety #sleep 2 caput Online_CS_StartStop Start wait 10 echo All Done - Terminal Window is Free to use.
With gtReceiver4 version each digitizer with get its own file to write to, each having the same run number but with and extra _### as well.
Known Issues
If error Fonts did not load, or something along these lines, then type following to fix
xset fp+ /usr/share/X11/fonts/100dpi
