Dig setup
From HELIOS Digital DAQ
Revision as of 23:02, June 2, 2015 by Crhoffman (talk | contribs) (Crhoffman moved page Dig setupmob to Dig setup)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
# Setup all digitizer delay windows M, K, D, D2
# also setup raw data length, data window, peak sensitivity
#  LEd threshold, channel enable, discriminator mode
# trigger mode, edge select, pileup mode, extension mode,
# extension enable, trigger configuration and time windows
echo "Mass setting of Digitizers to default operational values"
caput GLBL:DIG:win_comp_min -1000
caput GLBL:DIG:win_comp_max 0
caput GLBL:DIG:led_threshold 50
caput GLBL:DIG:raw_data_length 1.0
caput GLBL:DIG:raw_data_window 0.32
caput GLBL:DIG:d_window 0.20
caput GLBL:DIG:k_window 0.80
caput GLBL:DIG:m_window 3.5
caput GLBL:DIG:d2_window 0.20
caput GLBL:DIG:peak_sensitivity 3
caput GLBL:DIG:channel_enable 1
caput GLBL:DIG:pileup_mode 1
caput GLBL:DIG:trigger_polarity 1
caput GLBL:DIG:dropped_event_count_mode 0
caput GLBL:DIG:event_count_mode 0
caput GLBL:DIG:ahit_count_mode 0
caput GLBL:DIG:disc_count_mode 0
caput GLBL:DIG:event_extention_mode 0
caput GLBL:DIG:pileup_extention_mode 0
caput GLBL:DIG:counter_reset 0
caput GLBL:DIG:trigger_mux_select 0
#need to really put .4 for 400 ns? need to fix equation...
caput GLBL:DIG:disc_width 1.9
# clear FIFOs to insure no old events
caput GLBL:DIG:master_fifo_reset 1 > null
caput GLBL:DIG:master_fifo_reset 0 > null
## BUG BUG BUG ##
# PV that set the load delays bit does not seem to work.
echo "loading buffer delays"
caput GLBL:DIG:load_delays 0
sleep 0.1
caput GLBL:DIG:load_delays 1
sleep 0.1
echo "***********SCRIPT COMPLETE************"
caput GLBL:DIG:counter_mode 1
caput GLBL:DIG:master_counter_reset 0
caput GLBL:DAQ:DAQTimeDelayA 0.001
caput GLBL:DAQ:DAQTimeDelayB 0.01
caput GLBL:DAQ:BuildSendDelay 0.0
## Worked with John to set parameters for data taking, i.e.
## Digitizer using internal clk and having no trigger module.
## These numbers correspond to 0xE0051, 0x180, and 0x1 in hex
## For readback on VME01:MDIG1:reg_master_logic_status I see 81
caput VME01:MDIG1:reg_master_logic_status 917569
caput VME01:MDIG1:reg_sd_config  385
caput VME01:MDIG1:reg_vme_gp_ctrl 1
caput GLBL:DIG:led_threshold 2
