Dig setup
Jump to navigation
Jump to search
# Setup all digitizer delay windows M, K, D, D2 # also setup raw data length, data window, peak sensitivity # LEd threshold, channel enable, discriminator mode # trigger mode, edge select, pileup mode, extension mode, # extension enable, trigger configuration and time windows echo "Mass setting of Digitizers to default operational values" caput GLBL:DIG:win_comp_min -1000 caput GLBL:DIG:win_comp_max 0 caput GLBL:DIG:led_threshold 50 caput GLBL:DIG:raw_data_length 1.0 caput GLBL:DIG:raw_data_window 0.32 caput GLBL:DIG:d_window 0.20 caput GLBL:DIG:k_window 0.80 caput GLBL:DIG:m_window 3.5 caput GLBL:DIG:d2_window 0.20 caput GLBL:DIG:peak_sensitivity 3 caput GLBL:DIG:channel_enable 1 caput GLBL:DIG:pileup_mode 1 caput GLBL:DIG:trigger_polarity 1 caput GLBL:DIG:dropped_event_count_mode 0 caput GLBL:DIG:event_count_mode 0 caput GLBL:DIG:ahit_count_mode 0 caput GLBL:DIG:disc_count_mode 0 caput GLBL:DIG:event_extention_mode 0 caput GLBL:DIG:pileup_extention_mode 0 caput GLBL:DIG:counter_reset 0 caput GLBL:DIG:trigger_mux_select 0 #need to really put .4 for 400 ns? need to fix equation... caput GLBL:DIG:disc_width 1.9 # clear FIFOs to insure no old events caput GLBL:DIG:master_fifo_reset 1 > null caput GLBL:DIG:master_fifo_reset 0 > null ## BUG BUG BUG ## # PV that set the load delays bit does not seem to work. echo "loading buffer delays" caput GLBL:DIG:load_delays 0 sleep 0.1 caput GLBL:DIG:load_delays 1 sleep 0.1 caput GLBL:DIG:load_delays 0 echo "***********SCRIPT COMPLETE************" caput GLBL:DIG:counter_mode 1 caput GLBL:DIG:master_counter_reset 0 caput GLBL:DIG:master_fifo_reset 1 caput GLBL:DIG:master_fifo_reset 0 caput GLBL:DAQ:DAQTimeDelayA 0.001 caput GLBL:DAQ:DAQTimeDelayB 0.01 caput GLBL:DAQ:BuildSendDelay 0.0 ## Worked with John to set parameters for data taking, i.e. ## Digitizer using internal clk and having no trigger module. ## These numbers correspond to 0xE0051, 0x180, and 0x1 in hex ## For readback on VME01:MDIG1:reg_master_logic_status I see 81 caput VME01:MDIG1:reg_master_logic_status 917584 caput VME01:MDIG1:reg_sd_config 384 caput VME01:MDIG1:reg_vme_gp_ctrl 1 caput GLBL:DIG:led_threshold 2
