#!/bin/bash -l
# A script to allow the $EDM windows to start terminal windows for
# softioc, ioc and hopefully receivers.
# Each element in the system runs in an xterm that is running on the local
# machine where the script is first invoked.
# Because the xterms all are running locally it is easy to locate and kill
# them. Because things are started remotely by calling the same script the
# code is localized to a single file
gretTop=/global/devel/gretTop/9-22
gretTop5=/global/devel5/gretTop/9-22
baseLib=/global/devel/base/base-3.14.12.1/lib/linux-x86
runSoftIOC() {
cd $gretTop/gretClust/iocBoot/iocGretClustGT
pwd
export LD_LIBRARY_PATH=$baseLib
var=$(ps aux | grep st.cmd | grep gret)
var2=${var: -14}
if $var2 = "Clust ./st.cmd"
then echo "SoftIOC already running"; exit
fi
echo "Spawning SoftIOC"
xterm -T SoftIOC -sb -sl 1000 -e "./st.cmd" &
trigConsole() {
export TERM=vt100
echo " terminal trig"
xterm -T TrigCPU -sb -sl 1000 -e "telnet" "ts" "2016" &
ioc1Console() {
export TERM=vt100
echo " terminal 1"
xterm -T VME1 -sb -sl 1000 -e "telnet" "ts" "2001" &
ioc2Console() {
export TERM=vt100
echo " terminal 2"
xterm -T VME2 -sb -sl 1000 -e "telnet" "ts" "2002" &
ioc3Console() {
export TERM=vt100
echo " terminal 3"
xterm -T VME3 -sb -sl 1000 -e "telnet" "ts" "2003" &
# Inline portion begins here
# This part of the script runs the commands that will appear in the xterm
# windows, whether run remotely or locally. This is the only case
# in which the script is invoked with a parameter. The parameter is the same
# number that was entered in the menu by the operator in the interactive copy.
if [ $# -eq 1 ]
then
cmd=$1
case $cmd in
1) runSoftIOC ;;
2) trigConsole ;;
3) ioc1Console ;;
4) ioc2Console ;;
5) ioc3Console ;;
esac
exit
fi
