DCS2 computer
From GammaSphere DAQ
Revision as of 21:55, February 12, 2026 by Ttang (talk | contribs)
This is analysis computer for GammaSphere.
Network IP
192.168.203.56 or dcs2.onenet
Note to the Users
  • Use your personal ANL account to login.
  • Don't save data in your home
  • Your network home is located at /nethome/anl/<your ANL account name>
  • Use the network drive to save data.
  • Or Use /mnt/data0, this is a 2 TB M.2 SSD.
  • During experiment, you may be kicked out.
  • Network file system is located at /dgsdata, see Network Drive
  • 10 GB/s connected to network.
Common account for GammaSphere analysis
  • Account name dcsu
  • This account in managed by Ryan. Ryan will delete anything I don't understand.
  • The password will be changed for every 6 months.
Software
Software/Code Info. Location
ROOT 6.36.04 ROOT 6.36.04 /opt/root or /usr/local/cern/root_v6.36.04
KShell Shell model calculation /opt/kshell
Boost
InfluxDB3
Grafana 12.3 port 3000
Please let Ryan know if you want more packages or softwares.
Specification
This is an AMD Ryzen Threadripper 9980X 64-core (128-threads) with 256 GB RAM. It also equip with NVIDIA RTX PRO Blackwell GPU.
Component Specification
Motherboard ASUS Pro WS TRX50-SAGE WIFI
RAM 4 x 64 GB DDR5-5600 MT/s ECC RDIMM (256 GB Total)
CPU AMD Ryzen Threadripper 9980X (64-Core, 128-Threads)
GPU NVIDIA RTX PRO 2000 Blackwell (16 GB GDDR7, 4352 CUDA Cores)
Disk Samsung SSD 990 PRO 1TB (OS disk)
Network 3 x 10GB/s port
Storage and Disk
Disk Capacity Type Note
/ 1 TB NVMe OS disk. Don't save data in here
/mnt/data0 2 TB MVMe scratch disk. 700 MB/s read, 400 MB/s write
Network Drive
The physics file server is mounted on
Location Mount point Old aliases READ/Write by dcsu
fs1.onenet:/mnt/vol2/atlasdata/dgs dgsdata/fs1/vol2 /dk/fs1/dgs Read
fs2.onenet:/mnt/vol2/atlasdata/dgs /dgsdata/fs2/vol2 Read
fs2.onenet:/mnt/vol3/atlasdata/dgs /dgsdata/fs2/vol3 /dk/fs2b/dgs Read
fs2.onenet:/mnt/vol4/atlasdata/dgs /dgsdata/fs2/vol4 Read
fs2.onenet:/mnt/vol5/atlasdata/dgs /dgsdata/fs2/vol5 Read, Write for dcsu only.
LN Filling backup
/home/phy/dcsu/lnFill.
https://gitlab.phy.anl.gov/dgs-tools-pack/lnfill
Cron job
there is one active cron job for pinging the lnfill (IOC), ln2con, raspberry pi, and piserver1
