DCS2 computer
This is analysis computer for GammaSphere.
Network IP
192.168.203.56 or dcs2.onenet
Note to the Users
- Use your personal ANL account to login.
- Don't save data in your home
- Use the network drive to save data.
- Your network home is located at /nethome/anl/<your ANL account name>
- Network file system is located at /dgsdata
- ROOT 6.36.04 is available at /opt/root or /usr/local/cern/root_v6.36.04. Need to source the thisroot.sh.
- KSHELL avalible at /opt/kshell
- For any python packages for your own usage, please use virtual environment.
- Please let Ryan to know if you want any packages or software to be installed
Common account for GammaSphere analysis
- This account in managed by Ryan. Ryan will delete anything I don't understand.
- The password will be changed for every 6 months.
Software
| Software/Code | Info. | Location |
| ROOT 6.36.04 | ROOT 6.36.04 | /opt/root or /usr/local/cern/root_v6.36.04 |
| KShell | Shell model calculation | /opt/kshell |
| Boost |
Please let Ryan know if you want more packages or software, please let me know.
Specification
This is an AMD Ryzen Threadripper 9980X 64-core (128-threads) with 256 GB RAM. It also equip with NVIDIA RTX PRO Blackwell GPU.
| Component | Specification |
| Motherboard | ASUS Pro WS TRX50-SAGE WIFI |
| RAM | 4 x 64 GB DDR5-5600 MT/s ECC RDIMM (256 GB Total) |
| CPU | AMD Ryzen Threadripper 9980X (64-Core, 128-Threads) |
| GPU | NVIDIA RTX PRO 2000 Blackwell (16 GB GDDR7, 4352 CUDA Cores) |
| Disk | Samsung SSD 990 PRO 1TB (OS disk) |
| Network | 3 x 10GB/s port |
Storage and Disk
| Disk | Capacity | Type | Note |
| / | 1 TB | NVMe | OS disk. Don't save data in here |
Network Drive
The physics file server is mounted on
| Location | Mount point | Old aliases | READ/Write by dcsu |
| fs1.onenet:/mnt/vol2/atlasdata/dgs | dgsdata/fs1/vol2 | /dk/fs1/dgs | Read |
| fs2.onenet:/mnt/vol2/atlasdata/dgs | /dgsdata/fs2/vol2 | Read | |
| fs2.onenet:/mnt/vol3/atlasdata/dgs | /dgsdata/fs2/vol3 | /dk/fs2b/dgs | Read |
| fs2.onenet:/mnt/vol4/atlasdata/dgs | /dgsdata/fs2/vol4 | Read | |
| fs2.onenet:/mnt/vol5/atlasdata/dgs | /dgsdata/fs2/vol5 | Read/Write |
